help me build a sprayer!
/ help me build a sprayer! #1
twodogs
Pittsburgh, PA
Kubota B7800
Gentlemen-
I have a kubota b7800 & I recently purchased a plastic tank to store my off road diesel. I was about to purchase a 15 gallon sprayer tank/pump combo when I started to think that I could probably buy one of these drums & a pump a lot cheaper, or for the same money, get a better pump. My goal is to spray my orchard. We have about 40 fruit trees of various sizes. I have a FEL that I could carry the tank in & secure it with straps & hooks. I would also consider a 3pt setup. I am game to whatever suggestions you have.
/ help me build a sprayer! #2
Here is how I did it. I bought the Fimco 15 gallon spot sprayer. It has 2 threaded holes on the bottom that fit perfect on my 3 point cross bar, so I can bolt it in place. It was $79 at TSC. I bought a few rainbird sprinkler parts for about $6 bucks and with some rubber hose I had laying around I built a spray bar that give me about a 7' spray path. Just set it on my 3 Point hitch tilted up and it works perfect. Put a switch on the dash of thetractor for on and off and I am set to go.
/ help me build a sprayer! #4
With that many trees, you're gonna need a good size tank.
This is what I came up with to spray the lawn. I started with a fifteen gallon tank but made the 3-pt. platform big enough to hold a larger one. Works good for my applications.
/ help me build a sprayer! #5
PineRidge posted a thread about building a sprayer that was very detailed and seemed pretty helpful. It would be worth an hour or so to read over if you're going to take on something similar.
/ help me build a sprayer! #6
After converting a 25 gallon 4wheeler spot sprayer to a 3ph boom sprayer I can tell you you won't be able to build anything cheaper than you can buy it. But you can end up with a better quality sprayer that is better suited to your needs that a ready made one.
/ help me build a sprayer! #7
I guess it would depend on what you are spraying, ground, trees or both. If you look thru the Agri-Supply catalog(www.agri-supply.com), you will find quite a few options. And like Berniep stated, you will be hard pressed to beat some of the prices if you build up your own, especially if you consider your time involved in "re-inventing the wheel". I bought their plain 25 gallon spot sprayer tank/pump combo($138). Once you figure in all the piece parts and the shipping + time to assemble, it was hard to beat. This one already has the pressure gauge and a "Y" gate valve installed so adding a boom is about a 5 minute job(one side recircs to the tank for controlling boom spray pressure and to help with mixing and pump flushing, the other connects to a boom). It also has a 30' hose and wand plummed in near the gauge so you close both "y" valves and the pump cycles to 60PSI and stops automatically for spot spraying(pressure switch maintains 40-60 PSI automatically).
They have a basic 2 nozzel boom with 80" coverage for about $48(#56427). It comes with all the hardware/brackets and could be easilly connected to the bottom of the tank and the whole affair set in a FEL bucket. You might have to extend some wiring to be able to control the pump from the seat. That pump size will suport 3 of those type nozzels found on the 80" boom. That boom is also made by Fimco and I got the part numbers off the FIMCO website(they have all their manuals and parts lists online) and ordered an additional nozzel, screen and screw cap from them for that boom. Agri-Supply has the 1/2" hose to nozzel fittings that the nozzel screws into as well as the boom clamps to connect it to a 1" pipeboom(all inexpensive). I ordered up a "T" fitting and clamp from them for the center nozzel and converted the rest of my parts from the 2 nozzel 80" coverage boom to a 3 nozzel 120" coverage boom. That spray tank with 2.1GPM pump will run the three nozzels at a near ideal 20PSI/.47GPM without recircing any fluid to the tank. When at the proper height(18" above ground)Those Nozzels at 20PSI and moving at a comfortable 3MPH deliver 20 gallons per acre which is a good mix rate for the 2-4D that I lay down(1QT/20GAL/Acre) for weed control. When spot spraying with the wand, 20 gallons goes a long way. As long as your trees are not too high, that wand should work for light tree spraying also.
If I had it to do again, I would build a 3 nozzel boom from scratch to start with using those parts from Agri-Supply(one "T" and two 90 degree 1/2" nozzel elbows and brackets) and Fimco(three nozzels, screen filters and screw on retainer caps from the 80" coverage boom) and provide my own boom pipe(which I did anyway) and hose to connect it all together for about the same price in parts as the 2 nozzel boom that agri-supply sells.
Good luck
/ help me build a sprayer! #8
A couple of other things that may be helpful:
Adding a std hose gate valve before the "Y" valve will allow you to shut off the boom w/o disturbing the flow rate to the boom so you don't have to set pressure again.
I got a 7 nozzle boom, knowing that I probably didn't have a pump big enough to run them all but, it gives me the ability to do offset spraying if I find the need. Rather than having individual valves for each nozzle, I just use plugs that insert in each desired nozzle.
I found that the nozzles that came w/ my boom did not have check valves in them. It didn't look like it, but there's a lot of fluid in all that hose ... as I found out w/ several Roundup streaks where I didn't want them. I now have checkvalve strainers in the nozzles :)
/ help me build a sprayer! #9
I built my own using a 26 gal. spot sprayer. I attached mine on the back of my garden tractor with a quick attach brackets. Here is a picture of it. The left valve sets the pressure using the gage for the sprayer. The "Y" fitting turns on the sprayer and returns the overflow to the tank. The wand is attached to the "T" where the gage is located. They are plastic garden valves.
This is the sprayer on my tractor. I can spray a 60" path. I will make a larger one in the future. The wand is wraped around the tank and attached to the tank behind the seat.
This is the quick disconnect bracket on the sprayer that fits on the back of my garden tractor.
/ help me build a sprayer! #10
That is nice work on the garden tractor bracket. I had initially thought of something similar, but 200 pounds of fluid + the weight of tank and pump and boom and bracket might make my garden tractor go over backwards going up some of my hills.
Homebrew That is a great idea with the valve ahead of the "Y". That was a problem having to reset pressure when shifting between wand and boom when I initially set up with the 2 nozzel boom. I don't have that problem since switching to the 3 nozzel boom. The side of the "Y' to the boom is wide open and the side going back to the tank is fully closed. The pump connected directly to the 3 nozzel boom will deliver 20PSI with no need for adjustment. I just close the valve to the boom when I want to use the wand and open it wide when I want to go back to the boom. It does dribble a bit when the pump is shut off and the fluid in the hose continues to drain out the nozzels. Where did you get the strainer/check valves for your nozzels? I havn't come across any for my nozzels. It is not a real problem with 2-4D, but that would be something I would be interested in for spraying roundup.
/ help me build a sprayer! #11
I've done two using spray tips from Agri-supply and braided hose from mcmaster carr. In both cases we already had the tank/handsprayer combo. As stated in the other posts, if you start from scratch it will be more expensive. Converting the 15 gallons sprayer isn't too expensive though. I added a Q-D coupling to make the hand wand removable on the second one.
Machine Builders Network
Catalog: Current Buyer's Guide from Agri Supply® - Where we have Something for Everyone for your Farm Shop & Home
/ help me build a sprayer! #12
Nice Work on the Sprayer, BigDad !
Can you tell me where you got your spray nozzles?
I want to build something similar for my small yard tractor.
Thank You for any help you cangive,
Joe - From Romeo Michigan USA
/ help me build a sprayer! #13
Tractor supply is where I got my nozzle bodies, "T" s, nozzles and hose.
They still had all the stuff when I was there last week.
/ help me build a sprayer! #14
Here's my version. It has a 30 gal tank, 6 roller Silver Series Hypro pump, 12' foldable boom with nozzles @ 20". Under the pressure gauge in the 3rd picture is a valve for a spray wand to be added. The boom sprayer works great. Mark
/ help me build a sprayer! #15
Thanks BernieP and Briar!
They had the 15 gallon pump job on sale for $79.99 (reg $99.99)..
Pieced together nozzles...for another $25 ro so.. now just need to rig a boom on my aerator or dethatcher.. and plumb in a valve for hand or spray and I think I'm in business...
/ help me build a sprayer! #16
I got the tips at the local farm store. It's been a while, but I think I had two or three attempts to get the tips that fit my needs.
/ help me build a sprayer! #17
I have about 3 acres of grass to maintain. I am not looking for golf coarse quality turf, but something fairly weed free would be good. Can I assume that using liquid chemicals sprayed with a boom sprayer vs bags of week and feed would work out better?
I understand the cost of the sprayer parts, I just don't have any idea what liquid weed control chemicals would run. I know this topic is on the sprayers themselves, but this kind of falls in the same category
Thanks
Paul
/ help me build a sprayer! #18
Thanks
Paul
Seems like I always spend about 70 bucks on my three acres.
I have used various formulations of trimec. It worked ok.
I got some Triplet from my local fertilizer dealer it's a little more concentrated than trimec so you use less in the sprayer. It worked well the last two years. It's about 35 bucks a gallon and I needed a gallon and a half, gotta buy it by the gallon. This year I got some speedzone for 70 bucks a gallon and you need about a quart per acre on the low end. Seems to be getting my wild violets this time which is the reason I have been changing chemicals.
I added a surfactant to help it work better I don't remember what that cost. I have also added liquid fertilizer to it and plan to later but buying it from a tractor supply place can be expensive. I plan to get some from my family farm after planting season is over and get some leftovers if there are any appropriate leftovers.
Challenger 65-85C Tractor Service Manual (A63117)
Challenger 65-85C...
2 Row cole planters (A64119)
2 Row cole...
2007 TRAILMOBILE 53X 102 T/A DRY VAN TRAILER (A59912)
2007 TRAILMOBILE...
3 Bottom International switch plow (A64119)
3 Bottom...
8' DISC HARROW (A60430)
8' DISC HARROW...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
