Traction ztr stuck in mud
/ ztr stuck in mud #21
"I've never released the fluid when pulling my ZTR out of a bind. If it doesn't have enough traction to drive out then the wheels easily slip. I usually only need to move it about a foot and I can drive it out. " 4570 man
some of the consumer grade pumps have those rod bypass valve releases, the more commercial ones have a bolt you back off on the pump...don't force much either way as it is just a seal. i ALWAYS release the valve when towing or pushing w/o power. trying to move it w/o releasing that valve could put undue stress on the hyd system. you paid a lot for it & the pumps/motors are excessively expensive to replace. skidding it in mud might be ok but won't do that to mine..... only imho
/ ztr stuck in mud #22
"I've never released the fluid when pulling my ZTR out of a bind. If it doesn't have enough traction to drive out then the wheels easily slip. I usually only need to move it about a foot and I can drive it out. " 4570 man some of the consumer grade pumps have those rod bypass valve releases, the more commercial ones have a bolt you back off on the pump...don't force much either way as it is just a seal. i ALWAYS release the valve when towing or pushing w/o power. trying to move it w/o releasing that valve could put undue stress on the hyd system. you paid a lot for it & the pumps/motors are excessively expensive to replace. skidding it in mud might be ok but won't do that to mine..... only imho
Mine was a commercial unit with the bolt to back out. The pumps lasted trouble free for 1000 hours until the mower caught on fire. So I wouldn't have helped myself any by loosening the bolts.
/ ztr stuck in mud #23
It happens from time to time. It could pass for distracted driving!
I have to attach to the ROPS, not much else there.
2016 Isuzu NPR 20ft Box Truck (A61573)
2016 Isuzu NPR...
Challenger MT 700 Series Service Manuals Vol. 1 and Vol. 2 (A63117)
Challenger MT 700...
MF GC2300 fel replaced
1210 (A64280)
1210 (A64280)
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
2025 Spirit Electric Scooter (A61574)
2025 Spirit...
