Traction ztr stuck in mud
/ ztr stuck in mud #21
"I've never released the fluid when pulling my ZTR out of a bind. If it doesn't have enough traction to drive out then the wheels easily slip. I usually only need to move it about a foot and I can drive it out. " 4570 man
some of the consumer grade pumps have those rod bypass valve releases, the more commercial ones have a bolt you back off on the pump...don't force much either way as it is just a seal. i ALWAYS release the valve when towing or pushing w/o power. trying to move it w/o releasing that valve could put undue stress on the hyd system. you paid a lot for it & the pumps/motors are excessively expensive to replace. skidding it in mud might be ok but won't do that to mine..... only imho
/ ztr stuck in mud #22
"I've never released the fluid when pulling my ZTR out of a bind. If it doesn't have enough traction to drive out then the wheels easily slip. I usually only need to move it about a foot and I can drive it out. " 4570 man some of the consumer grade pumps have those rod bypass valve releases, the more commercial ones have a bolt you back off on the pump...don't force much either way as it is just a seal. i ALWAYS release the valve when towing or pushing w/o power. trying to move it w/o releasing that valve could put undue stress on the hyd system. you paid a lot for it & the pumps/motors are excessively expensive to replace. skidding it in mud might be ok but won't do that to mine..... only imho
Mine was a commercial unit with the bolt to back out. The pumps lasted trouble free for 1000 hours until the mower caught on fire. So I wouldn't have helped myself any by loosening the bolts.
/ ztr stuck in mud #23
It happens from time to time. It could pass for distracted driving!
I have to attach to the ROPS, not much else there.
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2013 Mack CXU613 T/A Day Cab Truck Tractor (A64556)
2013 Mack CXU613...
Cedar Boards (A65640)
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A65053)
2018 VOLVO SD75B...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
