zip tie tire chains
/ zip tie tire chains #1
wldrbob
swan river manitoba canada
white 2/60 case 830 w4 international cletrac cat
i saw these on youtube and thought i would tell you what i have used for traction aids for years a piece of light chain and a carabiner and apiece of wire ,, feed the wire and attached chain through your spokes on your drive wheel wrap around tire and hook up carabiner sometimes i use just one on a tire but i usaly put 3 on each easy to put on and easy to take off after your out of the snowbank or mud hole.. 25 bucks for the chain and carabiners and reusable many times.. 13 to 15 or more for the zip grip system and not reusable a lot cheaper than a tow but i will stick with my cheap chain system
/ zip tie tire chains #3
seen them and thought that is OK for a short stuck spot but if there are not a "Remove" tab on them then the cost would not be an issue IF they were reusable a few times. I think cost was OK and light enough to carry in trunk of a regular car... ONLY low speed for a small distance.
Mark
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
2024 John Deere TX (A64119)
2024 John Deere TX...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2013 PETERBILT 365 (A65643)
2013 PETERBILT 365...
