Zero Turn suspension forks?
/ Zero Turn suspension forks?
/ Zero Turn suspension forks? #12
I went and picked up fuel at the depot and a woman was mowing with a stand-on ZTR. She had quite the bouncy ride too. Our drought has made the ground rough and unforgiving so it sure is a hard way to make a living right now. There has to be a way to suspend them mowers so they ride better. (like Ferris?)
/ Zero Turn suspension forks? #13
The link to their site is in the first post. You can look.
It didn't list 1 for the 5R series you had mentioned calling them about your z530R . so I thought they may have steered you in what model may fit?
My SIL has a Gravely, with some sort of suspension. He loves it but, it cost him like $10k...
/ Zero Turn suspension forks? #15
Ok after doing some homework ( reached out to the company and never received a response) I found the model 500 unfortunately won't fit my Z545R. what I did was research the models they said it fit . looked up the part numbers from John deere. and found out it's made for a 5 inch tire and is 5.5 inches wide.The R500 series uses a 6 inch wide tire. and has a 6.5 inch width between the forks. So im hoping they make a wider 1 for the R500 series soon 🙏.
/ Zero Turn suspension forks? #16
just called the company and they have no intentions of producing 1 a inch wider. bummer.
Thanks for saving me the research time. Yeah, bummer. I'm not swapping to smaller tires, either.
/ Zero Turn suspension forks? #18
I put them on my mower and did not see that big of a difference. I still think the comfort glide or scags suspension sled are the most comfortable way to go for a zero turn.
/ Zero Turn suspension forks? #19
the guy had mentioned that they had rubber in them. and couldn't be welded on.
(INOP) CATERPILLAR EC25K STRAIGHT MAST FORKLIFT (A59823)
(INOP) CATERPILLAR...
Lone Star dump trailer (A55973)
Lone Star dump...
(2) Planter Row Sweeps (A60463)
(2) Planter Row...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2012 SOUTHERN 130 BBL VACUUM TRAILER (A60736)
2012 SOUTHERN 130...
Iranch IRGC40 (A60463)
