Buying Advice Zero Turn or Sub Compact Tractor?!
/ Zero Turn or Sub Compact Tractor?! #21
You might also look at the B 2620 which uses larger daimeter tires that might be advantagous on the wet ground.
/ Zero Turn or Sub Compact Tractor?! #22
Commercial ZTR like a Scag, Hustler, Exmark, Ferris for mowing. Tractor for tractor stuff.
I have tractors and ZTRs. Much, much rather mow with my Hustler Super Z unless we are talking heavy brush, then the tractor and bush hog are called into play.
I can mow my 2ac yard in an easy 45min with the Super Z.
Pretty sure Ferris and Hustler (at least) have some 0% financing going on right now. Horse owners especially should look at the diesel Ferris; apparently they are offering a significant discount to that group.
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
2021 New Holland Powerstar 110 (A60462)
2021 New Holland...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A60736)
2012 BRUMLEY...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 John Deere 6105E (A60462)
2015 John Deere...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
