Backhoe Zerks for KB 2485~ size?....
Status
Not open for further replies.
/ Zerks for KB 2485~ size?.... #41
Re: Zerks for KB 2485~ size?.... My 2 cents
I wish you guys would throw away those coupler ends for your grease guns. I use a one handed pistol type grip to pump and a flexible rubber hose with a needle point type tip instead of those darn couplers. Don't just settle for a cheap NAPA brand needle tip try a good one like a lincoln. Good auto stores carry them. One hand on the gun and the other holds the needle tip firmly in the center of the zerk. A couple squeeze's on the pistol grip grease gun with the other hand and it beats heck out of struggling with the coupler.
I think you should try it you will never have to struggle with those unruly coupler ends again.
rimshot
/ Zerks for KB 2485~ size?.... #42
The grease doesn't get where it needs to be on most fittings using a needle tip. The grease needs to be in the middle of the joints to do any good.
A needle tip just lays the grease along the edges where its doing no good at all.
/ Zerks for KB 2485~ size?.... #43
<A needle tip just lays the grease along the edges where its doing no good at all.>
Well.Not in my experience. If you pump until grease comes out of the joint that should be sufficient whether it comes from a barrel tip or a needle. To each his own.
rimshot
Grease in is grease in. I prefer bacon grease myself, it makes for a better smelling tractor when its fresh!:laughing:
/ Zerks for KB 2485~ size?.... #45
Hey Dustinfox you talking to a brick wall this guy won't stop, he fights with everyone not just you just ignore him like I'm going to do when it replies to my post
/ Zerks for KB 2485~ size?.... #46
Excuse me? I DO know how to use a grease gun! and my remark about a Kubota was a joke prompted by the fact that it is near impossible to find parts for my Kioti. So far I have had two parts lost or broken only to discover that the sizes specified cannot be found in the U.S. and I DID go to the Kioti dealer (which I stated earlier) and they don't even have the correct size. Don't you think I would have bought some if they did? So there is no need for stupid insults just because I am frustrated by the unavailability of Kioti parts. And are you serious that the solution is to re-tap the threads!
Someone who knows how to use a grease gun would not snap a zerk off, so I believe he has to assume you did not know how to use a grease gun
Just my :2cents:worth
:cool2:
/ Zerks for KB 2485~ size?.... #47
Now days poor quality steel is everywhere including zerks it could happen
The Kioti zerks are not steel, they're brass. If you're planning on ignoring me then hi-tail it off my thread until you can learn how to interact with others who actually have something to share of a positive nature. And as lilranch stated, (not verbatim), if the interloper 'knew how to use a grease gun' this dragging out of this thread into oblivion would not have happened.
Random speculation of what could happen in your world view is largely irrelevant here.
Facts and part numbers for the correct zerks are what this thread is about, nothing else.
Now drop it and move on.
/ Zerks for KB 2485~ size?.... #49
:cool2:
I've broken many grease zerks.
/ Zerks for KB 2485~ size?.... #50
I have removed 19 posts from this thread that do not meet TBN's standards for content. Please refrain from personal attacks, insults, name calling, etc. :cool:
/ Zerks for KB 2485~ size?.... #51
Why were some of my posts removed? I have followed the rules.
/ Zerks for KB 2485~ size?.... #52
Sometimes we remove posts that are in reply to posts that need to be removed in order to keep the flow of the thread.
/ Zerks for KB 2485~ size?.... #53
Ahh, I see now. Thanks for the input.
Murphy,
The posts removal isn't about anything you posted.
/ Zerks for KB 2485~ size?.... #55
otay whatever..
/ Zerks for KB 2485~ size?.... #56
Yea, I noticed mine got removed also. But the recommendation on the drilling and tapping to 1/8" pipe is still a option. We sell Zerks for about 16 cents and they are steel not brass. CJ
/ Zerks for KB 2485~ size?.... #57
I beg forgiveness if I misinterpret, but that post (quoted) makes it sound like you think the needle tip is used around the edges of a joint (i.e. where the grease squeezes out). This is not the case. The needle tip is placed right in the center of the zerk, where it presses in the ball, and the grease goes in... into the same place as if a standard grease coupler is used.
I agree that if you try to grease the edges of a joint with that needle tip, the grease won't be where you want it... and it would take you 5 hours and 22 minutes to grease around the whole tractor!!! :laughing::laughing:
-Mitch
/ Zerks for KB 2485~ size?.... #58
Thank You Muhammad! :thumbsup:
Muhammad deleted posts from this thread at my request to either close the thread, eliminate it completely, or edit it, as was obviously needed.
Any other interpretations are merely misguided wishful thinking.
I would say, however, I would have preferred it being eliminated completely, but I left the decision to the admin.
/ Zerks for KB 2485~ size?.... #60
The thanks wasmt to ypu it was to Muhammad , others also complained not just you, but that's right your "special"
Status
2015 A and A Melters A-110 Towable Hot Rubber Melter (A64553)
2015 A and A...
11in. Bucket w/ Teeth Excavator Attachment (A64194)
11in. Bucket w/...
2017 INTERNATIONAL 4300 4X2 S/A 26FT NON CDL BOX TRUCK (A67147)
2017 INTERNATIONAL...
JOHN DEERE 1705 - 6R36" VACUUM PLANTER (A64278)
JOHN DEERE 1705 -...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
2005 Airman PDS185S Towable Air Compressor (A64194)
2005 Airman...
