Zerkishness
/ Zerkishness #11
interesting write up, didn't realize it was gas. so it runs ok on unleaded? prob so being low compression. will you fully restore w/body work, etc? looks like collectors item. my TO35 (Standard motors diesel) was a bear to start, put purred w/the 4 cyl engine. keep up the work
/ Zerkishness
Aren't those old tractors nice? That TO35 of yours is every bit as much a collectors item as this one - they had real nice engines. Of course they are all good using tractors if so inclined.
It doesn't run any different on unleaded gas that I can tell. This new gas with alcohol smells funny but runs the same. Plugs look good. About 30 years ago I took the engine apart to measure everything just out of curiousity - and couldn't find any wear worth fixing. It didn't and still doesn't burn any oil or make noises. So I lapped the valves, put in new rings, and put it all back together.
No, no restore is planned. It's just our old backup tractor. We built our house and barn - lifted the walls and rafters into place - with it. Then we flattened our land, a little hay field, and yard. And today it is still the only tractor we have with a really good Cat II 3pt with draft control. Nothing else pulls that 8 foot Big Rhino 6 way rear blade through snow so nicely. This year it gets brakes & a new muffler. Next year: rear tires.
I have tried to pick up a few old parts for whoever restores it when I am done. It doesn't really need restoration. So in a pile by the fence are some old fenders, the lights, some optional FEL buckets, 5ft mower, cultivator, post hole drill, chains, water pump - and in the barn all the literature plus an extra 3 way hydraulic outlet - so it could be made to run even more attachments.
rScotty
HYSTER S50FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S50FT...
2017 Ford F-150 Pickup Truck (A59230)
2017 Ford F-150...
2014 Eager Beaver 50SL/3 53ft 60 Ton Tri-Axle RGN Low Boy Trailer (A59230)
2014 Eager Beaver...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
