Zenith Carb on '69 Ford 2000-Float setting?
   / Zenith Carb on '69 Ford 2000-Float setting? #21
doubt it is the glass bowl.
PROBABLY is a sticking float.
you need to look the carb over for a number. if you don't find one. hit a parts site like ytmag.com and look for the zenith replacement for your model and grab it's number.
basically there are large mouth and small mouth / flange carbs for these models.
   / Zenith Carb on '69 Ford 2000-Float setting? #22
Problem solved! I received my Carb kit yesterday and installed carb on tractor. The new needle and seat is working and there is no leak. Tried to start the tractor and it would not stay cranked or run. I felt behind the key switch and a wire had come off the key switch. I put the wire back on and she fired right up !!! We cut with a bushog for an hour to test the tractor and the tractor is running great! I want to thank everyone here on this site for all your help. I wanted to tell everyone what the solution was to my problem so that this thread could help others in the future. It is important for others that are looking for help on this site to complete there trouble shooting so others can learn from their experience.
Thanks Daryl
2000 Genie Man Lift (A50322)
2000 Genie Man...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A51219)
2016 INTERNATIONAL...
2014 RAM 5500 FLATBED TRUCK (A51222)
2014 RAM 5500...
2003 Pierce Fire Truck (A50323)
2003 Pierce Fire...
2001 DITCH WITCH JT1720 DIRECTIONAL DRILL (A51242)
2001 DITCH WITCH...
2025 78in Rock Bucket Skid Steer Attachment (A50322)
2025 78in Rock...
