Zenith Carb on '69 Ford 2000-Float setting?
   / Zenith Carb on '69 Ford 2000-Float setting? #21
doubt it is the glass bowl.
PROBABLY is a sticking float.
you need to look the carb over for a number. if you don't find one. hit a parts site like ytmag.com and look for the zenith replacement for your model and grab it's number.
basically there are large mouth and small mouth / flange carbs for these models.
   / Zenith Carb on '69 Ford 2000-Float setting? #22
Problem solved! I received my Carb kit yesterday and installed carb on tractor. The new needle and seat is working and there is no leak. Tried to start the tractor and it would not stay cranked or run. I felt behind the key switch and a wire had come off the key switch. I put the wire back on and she fired right up !!! We cut with a bushog for an hour to test the tractor and the tractor is running great! I want to thank everyone here on this site for all your help. I wanted to tell everyone what the solution was to my problem so that this thread could help others in the future. It is important for others that are looking for help on this site to complete there trouble shooting so others can learn from their experience.
Thanks Daryl
Unused Delta Crash...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
10x16.5 Tire Assembly (A51039)
10x16.5 Tire...
2018 Ford F-150 (A51039)
2018 Ford F-150...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
