OP
Bob_Young
Veteran Member
- Joined
- Jul 5, 2002
- Messages
- 1,244
- Location
- North of the Fingerlakes - NY
- Tractor
- Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
Well, raising the float didn't help. Raised it a good eighth of an inch. Still need to have the choke halfway out to have it run smoothly. The float seemed high to begin with....a good sixteenth less than your quarter inch benchmark, Chris.
Also tried the propane torch trick to no effect. I was still suspicious of the vacuum advance line to the distributor, so disconnected that and put my finger over the fitting at the manifold end. Had no effect, finger in place or not.
There appears to an acceleration pump built into the carburetor that's activated by a sudden drop in manifold vacuum. There's a spring loaded rubber diaphragm beneath the carb. bowl that forms the bottom side of a chamber that's connected to a nozzle that discharges upstream of the venturi. The discharge nozzle was clogged; I cleaned it out and can blow Gun Scrubber through it in the discharge direction, but cannot see through it or push a wire through it. It may have a ball check valve in it's base.
I have not figured out how fuel gets into the chamber controlled by the diaphragm. It did have some nasty old gasoline in it when I took it apart and I had to clean up everything in there, but the only passage from the carb. bowl I've found, ends in a small chamber that is blocked off by a brass screw. There's another mysterious brass device in the top of the chamber that I can't describe...gas may get in that way. However fuel gets in, it can't be just a simple passage....the discharge nozzle is below the level of fuel in the bowl.
There appears to be two jets of about the same size in series between the bowl and the main discharge nozzle....one at the bowl exit and another a bit further along angling upward toward the discharge nozzle. Didn't write down their sizes, will do so next time I'm in there. I believe fuel for the idle circuit is taken off somewhere between the two jets....this is something I have to confirm. If not, I don't see the purpose of having two jets in series.
Used my new gaskets when it went together this time. If anything it's slightly worse now when the choke's all the way in. It seems to stagger or bog when the governor opens the throttle to recover from the RPM drop.
After this latest go-round, I too began to wonder whether this thing needs a twist drill run through the main jet (whichever one it is). Could be that this is sort of a generic replacement carburetor and needs a bit of setup for the engine it's put on.
Sorry this is so long and thanks again for the suggestions.
Bob
Bob
