Z44 initial oil change
/ Z44 initial oil change #1
rfmr
NH
Kioti CK30HST
Will be doing my initial oil change (10hr) within the next few weeks. Question is, how do you get the oil filter off without making a complete mess since there isn't enough room to put anything under it to catch whatever oil is left in it?
/ Z44 initial oil change #2
On other vehicles where there was no room I would put a cardboard "shoot" under it and run the oil out to where I could collect it in a pan.
If you have an end where you can put a rubber hose on, that works good also.
/ Z44 initial oil change #3
Yep, a milk jug shute works well too. The 2544 blows to change the oil on as well. The engine oil drain is in a completely rediculous location that boggles the mind as to WHY CC would let it set where it does. /forums/images/graemlins/confused.gif
Joel
/ Z44 initial oil change #4
On my first oil change I followed someone's advice by loosening the filter with a wrench to where it could be turned by hand. I then slid a ziploc bag over the filter as far as it would go and unscrewed the filter by hand letting it fall into the bag when it came off. There were a few drops to wipe up afterwards but it worked well.
2022 EZ-GO ELITE...
8ft. 3 Point Blade (A65640)
8ft. 3 Point Blade...
Landhonor Skid Steer 3Pt Hitch Adapter (A62679)
Landhonor Skid...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2009 Infiniti FX35 Multipurpose Vehicle (MPV), VIN # JNRAS18W09M158535 (A64557)
2009 Infiniti FX35...
International 154 Cub Lowboy, Gasoline, 60" Mower  (A62679)
International 154...
