Z44 initial oil change
/ Z44 initial oil change #1
rfmr
NH
Kioti CK30HST
Will be doing my initial oil change (10hr) within the next few weeks. Question is, how do you get the oil filter off without making a complete mess since there isn't enough room to put anything under it to catch whatever oil is left in it?
/ Z44 initial oil change #2
On other vehicles where there was no room I would put a cardboard "shoot" under it and run the oil out to where I could collect it in a pan.
If you have an end where you can put a rubber hose on, that works good also.
/ Z44 initial oil change #3
Yep, a milk jug shute works well too. The 2544 blows to change the oil on as well. The engine oil drain is in a completely rediculous location that boggles the mind as to WHY CC would let it set where it does. /forums/images/graemlins/confused.gif
Joel
/ Z44 initial oil change #4
On my first oil change I followed someone's advice by loosening the filter with a wrench to where it could be turned by hand. I then slid a ziploc bag over the filter as far as it would go and unscrewed the filter by hand letting it fall into the bag when it came off. There were a few drops to wipe up afterwards but it worked well.
Pair of 480/80R36 Tires (A65640)
Pair of 480/80R36...
2017 P.J. Deck Over Trailer, VIN # 4P5F82021H1265098 (A65563)
2017 P.J. Deck...
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
Wolverine Quick Attach Mulcher (A66285)
Wolverine Quick...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
1995 Jeep Wrangle 4x4 Soft Top (A62613)
1995 Jeep Wrangle...
