Z-Force 44 blades
/ Z-Force 44 blades #1
ibjim
I just purchased a set of blades from a Cub dealer. The new set is similar, but a little different them the originals. The dealer sold me Part No. 759-3939 and the manual parts list shows Part No. 01008616. I'm wondering if the original blades are high lift and the replacements standard? Or if the new ones are a replacement?
/ Z-Force 44 blades #2
Do they look as heavy as the 01008616 blades? Those 01008616 blades are as thick as the Cub Commercial blades, I don't have a set of 3939 blades here to compare. I would want the 01008616 blades if it were my machine.
/ Z-Force 44 blades
Thanks for the initial reply Gamble77. The box with the new set of blades has Part No. 759-3939 on it and the blades have Part No. 742-3036 stamped on them. I can't see a number on the original blades and was unable to get them off to look closer. They originals do look beefier and are ~15.5 inches long and the replacements are ~16 inches long. After searching further, it looks like Part No. 742-3036 is superseded by 759-3939.
It did sharpen the blades while under the mower.
2010 John Deere 4720 58HP 4WD Utility Loader Tractor w/ Titan Aerator (A66734)
2010 John Deere...
2017 Ford F-250 Ext. Cab Service Truck (A66736)
2017 Ford F-250...
2015 Chevrolet Silverado 2500HD Crew Cab Knapheide Service Truck (A68183)
2015 Chevrolet...
Unused 2021 Unused Paladin MD60SC 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 Unused...
2004 FRAC TANK 500BBL WHEELED (A68842)
2004 FRAC TANK...
CAT R500/D9R Ripper Teeth(6) (A68134)
CAT R500/D9R...
