Your towing rigs and trailers
   / Your towing rigs and trailers #2,021
I am going to add towing mirrors here pretty quick, leveling kit, 20 inch wheels, 33 inch Toyo open countries,
Is there any advantage to adding larger wheels? I understand that they look nice, but do they help with ride, mileage, or anything?
   / Your towing rigs and trailers #2,022
Some what, they seem to me, personally, to be little better when towing. Not as much sway tire wise. Ride is personal preference I think. Little more firm. Mileage, not really. The main reason with going with the twenty inch wheels, friend of mine had a set to fit this truck like I wanted and I swapped work for them. The tires will help hold the rig up in pastures and hayfields. They will be 12.50 inches wide. The rims are 9 inches wide I believe. I would have probly stayed with the factory 17 inch if not for that, and swapped rims later on. I know twenty inch tire is more expensive . That I don't like! LUTT
   / Your towing rigs and trailers #2,023
With the leveling kit, does that raise the front end up to be level with the rear? If that's a the case, does the truck squat when heavily loaded? I thought the reason the back end was higher was
Because when they are loaded the truck is then level?
   / Your towing rigs and trailers #2,024
Just curious as to the final drive (differential) ratio and whether taller tires will create an issue there?
   / Your towing rigs and trailers #2,025
   / Your towing rigs and trailers #2,026
With the leveling kit, does that raise the front end up to be level with the rear? If that's a the case, does the truck squat when heavily loaded? I thought the reason the back end was higher was Because when they are loaded the truck is then level?
Yes that is the intent for the rake in trucks. I do not like the level look on a truck that's not hauling. But to each there own. Some guys level then do air bags too so it's level no matter what.
   / Your towing rigs and trailers #2,027
That's why I don't plan on leveling my new F150. My Tacoma was always nose up when towing/hauling until I had to rebuild the rear springs, and had them done such that I had some lift in the rear before replacing the bumper or loading the bed.
   / Your towing rigs and trailers #2,028
Nice setup. I wish Mitsubishi offered those diesels here. What typical mpg, L/100km do you get Marcus ?
With some thought to economy (like keeping the speed limits) I can get it down to 10.9 l / 100km. Normally i get 12. Towing the trailer 14-16 depending on towed weight.
I have no idea what that means in mpg, two conversions and an inversion is just too much... :)
/ Marcus
   / Your towing rigs and trailers #2,029
/ Marcus
You guys do Liters / 100 KM? Man that's a weird set of units. :p
   / Your towing rigs and trailers #2,030
/ Marcus
That's almost 22mpg US - nice !
Rgds, D.
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
MAHINDRA MAX 26L LOADER (A57192)
MAHINDRA MAX 26L...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
2018 FORD F150 Ext Cab 4X4 Pick-up Truck (A53422)
2018 FORD F150 Ext...
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
