Your towing rigs and trailers
   / Your towing rigs and trailers #2,021
I am going to add towing mirrors here pretty quick, leveling kit, 20 inch wheels, 33 inch Toyo open countries,
Is there any advantage to adding larger wheels? I understand that they look nice, but do they help with ride, mileage, or anything?
   / Your towing rigs and trailers #2,022
Some what, they seem to me, personally, to be little better when towing. Not as much sway tire wise. Ride is personal preference I think. Little more firm. Mileage, not really. The main reason with going with the twenty inch wheels, friend of mine had a set to fit this truck like I wanted and I swapped work for them. The tires will help hold the rig up in pastures and hayfields. They will be 12.50 inches wide. The rims are 9 inches wide I believe. I would have probly stayed with the factory 17 inch if not for that, and swapped rims later on. I know twenty inch tire is more expensive . That I don't like! LUTT
   / Your towing rigs and trailers #2,023
With the leveling kit, does that raise the front end up to be level with the rear? If that's a the case, does the truck squat when heavily loaded? I thought the reason the back end was higher was
Because when they are loaded the truck is then level?
   / Your towing rigs and trailers #2,024
Just curious as to the final drive (differential) ratio and whether taller tires will create an issue there?
   / Your towing rigs and trailers #2,025
   / Your towing rigs and trailers #2,026
With the leveling kit, does that raise the front end up to be level with the rear? If that's a the case, does the truck squat when heavily loaded? I thought the reason the back end was higher was Because when they are loaded the truck is then level?
Yes that is the intent for the rake in trucks. I do not like the level look on a truck that's not hauling. But to each there own. Some guys level then do air bags too so it's level no matter what.
   / Your towing rigs and trailers #2,027
That's why I don't plan on leveling my new F150. My Tacoma was always nose up when towing/hauling until I had to rebuild the rear springs, and had them done such that I had some lift in the rear before replacing the bumper or loading the bed.
   / Your towing rigs and trailers #2,028
Nice setup. I wish Mitsubishi offered those diesels here. What typical mpg, L/100km do you get Marcus ?
With some thought to economy (like keeping the speed limits) I can get it down to 10.9 l / 100km. Normally i get 12. Towing the trailer 14-16 depending on towed weight.
I have no idea what that means in mpg, two conversions and an inversion is just too much... :)
/ Marcus
   / Your towing rigs and trailers #2,029
/ Marcus
You guys do Liters / 100 KM? Man that's a weird set of units. :p
   / Your towing rigs and trailers #2,030
/ Marcus
That's almost 22mpg US - nice !
Rgds, D.
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
(2) USED 3500 LB IDLER TRAILER AXLES (A57192)
(2) USED 3500 LB...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
UNUSED FUTURE CLG72 72" HYD CURVED LOG GRABBER (A57193)
UNUSED FUTURE...
2005 IC Corporation PB105 School Bus (A55852)
2005 IC...
