Your input?
/ Your input?
We have 10 acres, 7 horses, and do all the things you mentioned you plan on doing. Staying away from brands (theirs plenty of info to help you decide that), 25 -35 hp will do all you need and then some. (I have a 25hp gear that works fine).
Thanks for chiming in, that's good info from somebody with a comparable setup.
I thought i mentioned it, but we are in Georgia. So no chance of snow :) The whole clutching you mention... that's a good point and i hadn't thought about that. How does the PTO speed work in relation to the tractor RPMs? This is where the newbieness kicks in. How are the PTO RPMs kept constant? On any tractor i suppose, not just HST... If you're mowing or spreading etc... What all do you need to do on a gear vs HST?
As for post hole digging... Good info, didn't know that. I think we're fairly rock-free here. It's mostly the red Georgia clay that we'll have to contend with and some tree roots here and there probably. The thing is what we want to do enough fence work spread out over enough weekends that renting is probably going to be expensive.
Good luck and let us know what you buy!
Thanks and will do!
/ Your input? #22
Speaking from the other side. Alot of what you describe fits with what I have on my property although mine is 6 acres and I don't have the additional 10 to mow. I have a MF2310 + a Hustler 60" ZTR mower which I feel is the perfect combo and size. As for mowing there is nothing better than a ZTR.
As for the tractor and if it fits within your budget, get the backhoe. I could not live without mine, its the most versital tool I have. I clear fence rows, haul logs for cutting, flower bed prep, compost turning, stumps, posts, and of course holes an trenches.
Other than using a bush hog why would you need a larger tractor? Once a field is done once or twice with a bush hog a quality finish mower will do a great job moving foward. Before my purchase I questioned the size as being to small but, I have yet to reget and would not change a thing. The little tractors can look like glorified lawn mowers but, they are serious work horses. Unexpectedly and I believe because its small, the wife loves the tractor so, when doing clean up chores, I'm on the ZTR with a yard trailer and she is on the tractor.
One thing I've been sort of currious about is what is cost of ownership (gas, oil, parts, etc) between different size of machines over a year of the same hours?
Good luck on your purchase. Its a fun but hard decision to make.
/ Your input? #23
With the HST transmission you have infinate speed control without affecting your PTO speed. Works very well when using a snow blower, or a rototiller.
As for the Mahindra's, the 2816 has a few less creature comforts than the 3316. The 3316 has a more rummy platform and the HST transmission is smoother and quieter than the 2816 transmission. Both are solid and very trouble free.
Good luck with your shopping.
/ Your input? #24
Airic raises a good point. There are days when it would have been really nice to have a little BX with a backhoe around my place. Would be great for pretty much most of what I can think of wrt. backhoe use.
I've pondered the option myself of some day picking up a little BX with a backhoe to replace my Husqavarana riding mower :)
I do not think that I would want to be mowing MY pasture with a finish mower though. Before I started tractoring, I thought this would be an option. I hit WAY too many rocks, logs, etc. etc. for a finish mower to last on my pasture. I'm pretty darn glad I have a bushhog for it. YMMV.
/ Your input? #25
I think that your HST experience is an aberration. HST tractors have brakes and parking brakes just like non HST tractors.
Are there no 0% financing plans from either Kubota or Mahindra at this time? Generally a good reason to buy new is 0% financing? How about JD? I'm surprised they would end these - I expect they would need to push sales like crazy these days!.
If you are not getting 0% on these tractors, you might also want to look at used but relatively new. You should be able to get a great deal on one that is a year or two old that has done its initial bit of depreciation. The interest rates you quote are not far from what you can get on a secured line of credit. You can save quite a bit getting a 100-200 hr old used L3240 or L3130 which is practically brand new anyway. I don't know how high sales taxes are in Georgia but you can usually also save sales taxes on a private sale as well.
/ Your input? #26
Thanks and will do!
My sister is outside Atlanta - I seem to remember the blizzard of 93 dumping a foot on Atlanta!! (OK - I wouldn't have a snowblower down there either :) )
PTO speed is set by the engine rpm's. You get the rpm's up to the point on the tach that indicates your pto is at 540 rpm. The engines revving pretty good at that speed. Now with a gear tractor this will come into play when bushhogging uneven cuttings that may run heavy to light. If you get into really thick stuff and the engine starts bogging down you can either slow your forward progress or raise the bushhog and go over the patch again in a lower gear or if you have a gear tractor with two stage clutch you CAN slip the clutch. This keeps the pto at full rpm but takes the tranny turning the wheels out of gear. Problem with doing that is as I mentioned - hard on the clutch. Kind of like burning rubber in a car by revving the engine and popping the clutch. This is not an issue with an hst. You rev the engine to proper pto speed, and put it in the proper range (most have 3 - low med and high. You'd probably be doing most things in med). Step on the pedal and go, get into heavy stuff and just let up on the pedal a little and you slow down but the pto doesn't and there's no added stress on the transmission parts since it's designed to do just that.
re post hole digger - you can always buy one and try it, you may be lucky. I've heard that hardpack clay can be pretty tough to get bite in without downpressure (a 3 pt just has the weight of the digger. A skidsteer mount has the down pressure of the bucket and whole front of the machine). guess you can always try the 3 pt if you have plenty of time, then if you get a long weekend you can try and rent a machine and knock off a whole bunch in a long weekend. Just know if I had to lay out pastures with posts every 8 feet I'd rent a hydraulic one. I've seen them work and nothing stops them short of solid rock shelf
/ Your input? #27
On HST rolling on a hill... a manual tractor in neutral will do the same thing only much faster. So the lesson is: set the park brake. I forgot to do that once on my HST. Parked it with a trailer attached behind. Went out to the store. Came home to find it jack knifed and a nice gash left by the trailer on it's pretty green fender. Learned my lesson: set the part brake.
On PHD. I have hard clay but few rocks. No problems at all digging holes. I don't have a lot of fence, only about 500', but I have yet to shear a pin. Look for a PHD that uses cheapo soft steel bolts instead of some custom shear pin. Here's the difference I found: cheap bolt $1.50, shear pin $9.00. Bolts are availabe everywhere, shear pins not. Or consider adding a slip clutch. They are usually less than $100. Put that on and no more shear pin issues. I don't see too many used PHD around here. And when I do they want nearly new prices. So get the PHD with the tractor.
On the 2 stage clutch. At least on mine, with fully sychronized gears, I don't think you are slipping anything when you depress the pedal half way to disengage the drive train. For sure it's designed to do that. I prefer the 2 stage to the electric over hydraulic PTO clutch that some have (more to go wrong here).
Do take the time to look at Kioti. Free loader on CK's. 0% financing on some. You should be able to get into a CK30 with loader for around $16K. If TYM is nearby, I'd also look at the T273 or T330. The T273 is a super value and compact in size.
/ Your input? #28
those kiotis musta went up in price in last 6 months or so,I bought a ck30 in june I think for 13,000,no loader,but you said the loader was now free.
Those kiotis are well made tractors,only got about 50 hours on it so far, but its a solid tractor,mines gear/shuttle shift,guess hst would add a couple more thousand,but you don't need hst,[I wouldn't even want it],,mine runs a tiller just fine in low first,thought it might be to fast but its just the right speed really,[been going to slow I guess on my other tractor].
Alls else you need besides attachments,is a lawnmower,and if money is a problem,you could just get you a sears 50 inch cut,something or other,sometimes those will last you 9-10 years,[mine has],so for about 18,000 19,000 or so,you'd be set up to brush hog,mow your yard,do fel work,drill your post holes and till your garden!
/ Your input? #29
Oh,forgot to mention,my ck30 kioti's hitch is not jerky like they say the one kabota's is.
/ Your input? #30
If it was me, I would take a good look at either the Mahindra 2815HST, 3215HST, or the newer 3316HST. The Kioti CK30HST or CK35HST are very good machines also. I think that your monthly payment will be a lot lower with the Kioti with their present financing deals. And as has been said before, as long as a tractor with HST is adjusted properly it has little or no movement when the pedal is not depressed, but you SHOULD still use the emergency brake when leaving the tractor. These are very nice sized tractors and I believe that you would be satisfied with any of them. Oh, the 3pt lift capacity is 2646lbs on the 3316. the spec shown is a misprint.
Just my opinion, and that is not worth all that much. ;)
/ Your input?
Again thanks for all the feedback, i appreciate you all taking the time.
RE Backhoe: I'd like to have one (more power toys is good :D) but have a hard time justifying the extra $$$ when i really don't foresee us needing it but a couple times (no trees or big rocks around to uproot for example) and thus renting one for the few times we'd need it would be much cheaper.
RE PHD: I think we'll give a 3PH one a go. Friends of ours have one and have successfully used theirs to put up fencing. Since we're talking about a few hundred feet, and none of it critical, i think we'd like to try using our tractor for it instead of renting over several weekends. We'd be looking at the price of the auger ($500-$1000 tops) vs renting equipment several weekends (at least $200/weekend).
RE HST: It sounds like it has some advantage, and that some of the disadvantage we experienced really would show up with a manual transmission as well. I don't like the idea of having to slip the clutch to manage the forward motion while maintaining enough RPMs for the PTO. We'll have to take another look and compare the brakes etc on them.
RE 0%: Both Kubota and Mahindra have 0% programs. Just the term is different. With Mahindra they have the 0%/$0 down for 60 months for the 2816. For the 3316 they don't have a 0% program; it'd be 4.49% for 60 months. The monthly payment for the 2816 would be around $250, and about $75 more for the 3316. Not sure the 3316 is worth that much more for our situation? Kubota has only 24 or 36 months at 0%/$0 down. The Kubota L3400HST or L3240 (price is pretty much the same due to the L3240 being from pre-price increase), with 0% for 36 months, would come out to about $525/mo, which would be more than twice that of the 2816 and about $300 more than the 3316. Looking at the other financing options Kubota offers, they cannot get as low as Mahindra's. Comparing the L3500HST/L3240 vs the 3316 for example, the 3316 would be about $1500-$2000 cheaper, and the rate would be 1% lower. So Mahindra's got Kubota beat on price and financing it would seem.
I spoke with the Kioti dealer on the phone today. Their deal is either a) get a free FEL, but not the lower rates (and thus the rate is the standard agricredit rate which apparently is 10.4%(!?) according to the guy) or b) pay for the FEL but get the lower rate, which is 0% for 24 months and goes up to something like 4.some% for 84 months IIRC. Not bad? The CK27 on paper sounds like a good comparable to the 2816 with some extra features here and there, and the price is $13,700 or thereabouts. The CK25 is $11,700 or so, but i'm not sure that'd be too small a tractor for what we'd need? They don't have a CK30 on the lot, so we wouldn't be able to test one, and i don't know what the price is. It may be a good option as something between the other options. In either case the choice would be get a free FEL but finance at a higher rate, or pay $3100 or so extra for the FEL to get the lower rate. Not sure which one would work out in our favor yet. We're planning to go by the Kioti dealer Saturday morning to check 'm out in person and talk some numbers.
I looked for a YTM dealer, but the closest is 90+ miles away, which is too far to be practical.
The way things look this far, to me it seems the Mahindra 2816 is the one to beat for our situation? Its specs are in line with the comparable Kubota and Kioti, but with a better financing deal. On top of that the Mahindra dealer is relatively close by (20-ish miles or so), and we have 2 friends who have worked with that dealer before and have been pleased with the service. (Free pickup / delivery for maintenance for example.) The thing i want to make sure though is if that 2816 would be a good fit for what we'd need. Is it too big, too small, or about right? Unless i'm misunderstanding those of you who have similar situations, it sounds like it'd be a good fit size/power wise?
/ Your input? #32
If the CK27 fits your needs, then so would the CK25. Saving $2K and only giving up 2 HP would be a no brainer for me. That $2K will buy you 2 or 3 implements. Remember the CK25/27/30/35's are the same except for HP. Same loader, same frame, same everything. I'm surprised a dealer still has a CK25. They are being replaced by the CK27. The difference is in emissions standards. To get to the new emission standards changes were made that also resulted in an increase in HP. The dealer may be even willing to bargain some more on the CK25. He's probably had it a while.
The problem I see with 25/27 HP is that it really limits you to a 5 foot bush hog. I would want a 6' bush hog unless you want to spend a lot of time on your tractor. Maybe you could run a 6 footer on a gear model IF you're only cutting thinner, shorter vegetation. For the other chores you have described PTO HP matters less. For the mowing alone, the CK35 would be better suited for you and a closer comparison to some of the others you are considering.
BTW, I own a CK25 gear and love that tractor.
/ Your input?
Well, our pastures seems to be grasses and perhaps some brush-y / stalk-y looking stuff that may decide to pop up. That stuff doesn't seem to be thicker than maybe my thumb. Would a 5' / 25hp machine do that? Or is a stronger tractor really needed? (It's good to be future proof of course...)
/ Your input? #34
I have 4 horses on 11 acres of my 100acre farm. I have multiple tractors and work full time as well as farm. Actually, to be fair, my wife farms full time, I help :)
For what you are looking to do, a 30hp (engine) tractor will do everything, and not want for power ever. You could go with the B3030 Kubota, it will work ok. It's a fairly nice tractor ( I have been looking at them too to use as our small duty utility and mowing tractor) You may be better off with a heavier tractor like the Kioti, and it will cost less. HST is very nice, you won't regret it, especially if you need to back up and go forward a lot. The smaller L series tractors are ok but, take it from our experience, ANY tractor you buy should have extendable rear links on the 3ph to help hook up equipement. Otherwise, you will need to muscle things around sometimes to get them hooked up. It is the single biggest problem my wife has with the tractor. Sometimes I have to be there to hook up the equipment.
The PTO is based on engine speed. Set the throttle at the appropriate speed and go. This is where HST works great, you can vary the speed of the tractor around obstacles but continue running the PTO at the right speed.
You have a riding mower already, you will need to clip the pasture so that is the more important chore for this tractor. This is where PTO horsepower makes a difference. Tall pasture can really bog you down.
Everyone will tell you to get a rear finish mower or bush hog. I would seriously suggest you get a flail mower. I have both, the flail is far better UNLESS you have a lot of rocks. In that case the hog is better. Otherwise, the flail gives you the best of all worlds, you can get a nice finish cut like you want on the lawn, or you can go into tall weeds and chop them up. The clippings will compost much faster than the long bits you get with the bushhog. Agrisupply sells Caroni flails. Get a 60 or 72" model. The hydraulic offset model is nice to get under fences and low trees.
Bump up your tractor size by one notch now, you won't be sorry or need to replace it ever.
The backhoe is always nice. Don't buy it. They are expensive and take up a lot of shed space for the few times that you use it. 3pt backhoes are $4,500 and a pain in the butt to put on and take off. I actually do use mine quite a bit. However, for the few times you will need it, once or twice a year, rent a mini excavator. They can get much more work done in a shorter time for a few dollars. I have rented them too and they are really great. More fun to use than the backhoe anyway....
Good luck, have fun, stay safe
/ Your input? #35
I just went through the same exercise as you and wound up getting a Kioti CK30 HST with backhoe. The only reason I splurged on the BH is I got a very big discount because the dealer had used it as a demo. BUT, it's going to pay for itself within 2 years I have figured because I have to do a lot of work around the house.
The other choice would have been Kubota, but not the L3400 due to all of the talk about the 3ph.
The deciding factors for me were that, for about the same $$, the Kioti is heavier, better warranty, better financing, higher hydraulic flow and a dealer verified as trustworthy.
As for HST, if you get it you will never regret it.
Good luck!
/ Your input? #36
Bush hog size doesn't determine what you can cut, but rather how fast you can get the job done. A foot in width can make a big difference time-wise. But, then again if you are only cutting once or twice per season maybe you don't need a bigger bush hog.
/ Your input? #37
Lots of great advice here. A couple of things I would note as definitely required is an extendable 3 point lift arm. I dont have it on mine and it is a pain to hook up even with the quick attach that I have welded on to mine. THe other thing is your will not regret getting either an HST or my preference is a shuttle shift. The shuttle shift gives you a little of both worlds. I hardly ever use the clutch on mine and just shift up or down or neutral as needed.My tractor has 4 gears with a high, med, low,neutral and reverse in each gear. You can find the right speed you need somewhere in those 12 forward/ 4 reverse and some mfgs.have 12/12. I like to pick a gear where my average working speed is in medium range then if I need to slow down, I just bump it to low or high if I want to speed up. Just about all the tractors mentioned here would be good for you. 25-30 HP is more than enough for 10 acres and it would pull a 5 or even a 6 foot bushhog if you dont let it grow up to bad. I could never justify a flail mower at $4-5K for mowing 10 acres or a back hoe either. As for Kioti, they have good warranty but I havent heard that they fixed their loader arm cracking problem other than add some monstrosity bolt one attachment to the front so I would check that out further before buying one. Mahindra, Kubota are both closest thing you will find to a US made tractor (think assembly plants in USA)versus assembled in Korea or China. It all boils down to which one feels the nicest to you and the wife PLUS the best dollar value for the HP. I dont think that you with find that to be the Kubota, New Holland or John Deere. I personally would stay away from Montana/Farmtrac situation at this time regardless of price.
As for PHD. My place is in foothills of the Ozarks which is hard clay coleche with some areas being more 1" rock than clay and the PHD digs fine with out downward pressure. You do have to watch out that it doesnt auger in too fast and then you have a time to back it back out of the ground. By the way, best way to do that is turn the drive shaft with a pipe wrench. DONT even try to turn the auger as it is much too hard. BTDT.
/ Your input? #38
I think the Mahidra 2816 would be a great fit. I have a 3215, which is now a 3316 and it has been great. The 2816 should do everything you want. Have you checked to see if you could demo any?
/ Your input? #39
Valorum, what part of Georgia are you in? I'm in NE GA, we have several Kubota dealers around. The prices can vary by $1000 or more.
Look at the skid steer-type quick coupler for the FEL. It really adds versatility.
I have a B7500HST with the 60" mid mower with FEL and a M9000 shuttle shift with FEL.
I am currently thinking about trading the B7500 for a L3240HST or L3940HST with FEL and going with a 6' flail mower. The L3240HST looks like a great tractor.
/ Your input?
Canton, so NW. We haven't really checked into other Kubota dealers, but i'll take a look to see who's around over on this side. Do you have any particular dealer you'd recommend? If you're NE, it'd probably be too far for us, but worth a shot.
I also found out that Massey Ferguson has the 0% financing, and there's a dealer nearby, so we should probably check them out as well. Any feedback on that brand compared to the others discussed here, and recommendations for models to look at? From paper specs the 1529 sounds like a candidate? Too bad it looks like they're closed on the weekend, so we can't actually test drive one without taking a day off :(
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
16ft T/A Utility Trailer (A64557)
16ft T/A Utility...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
