You need balast or you will trash your front axle!!!! really?
   / You need balast or you will trash your front axle!!!! really? #41
I have to admit . . And have in my pists . . If an operator is willing to operate with only one axle in contact with the ground . . Then you can shift weight. But that is neither an acceprable ir safe operating condition by tractor definition. I believe that definition requires each axle and tire have ground contact. Would anyone disagree with that definition to operate the tractor ?
So at that point . . . Math is not a function because unless you add or remove air in tires . . Or alter the pitch/slope of the land . . You can't get "down" any lower than tires and wheels and axles being in ground contact. And all the leverage you use stops when you can't go down on one side and up on the other. Now you can alter the height the weight is carried at just as you can change the ground slope or air pressures in tires . . . But all ballast does is keep the 2 axles and 4 tires in ground contact and if 2 axles and 4 tires are in the exact same spot . . . More ballast on the rear increases the rear axle load but thats the ballast doing it. But I see no way for front axle load to be reduced by ballast.
As I opinioned before . . more ballast on one end of the tractor gives the operator a choice to add more weight on the front end but i see no way to lessen the weight that already exists on that front axle UNLESS you are willing to violate the tractor definition of 2 axles and 4 wheels in ground contact.
Now I'll be happy to read and listen to other viewpoints as long as the one standard is a tractor definition of all 4 wheels and 2 axles in ground contact.
Who knows . . uf this debate has often repeated in the past . . maybe I'll have to say I'm in error. Lol
   / You need balast or you will trash your front axle!!!! really? #42
I have to admit . . And have in my pists . . If an operator is willing to operate with only one axle in contact with the ground . . Then you can shift weight. But that is neither an acceprable ir safe operating condition by tractor definition. I believe that definition requires each axle having ground contact. Would anyone disagree with that definition to operate the tractor ?
So at that point . . . Math is not a function because unless you add or remove air in tires . . Yor alter the pitch/slope of the land . . You can't get "down" any lower than tires and wheels and axles being in ground contact. And all the leverage you use stops when you can't go down on one side and up on the other. Now you can alter the height the weight is carried at just as you can change the ground slope or air pressures in tires . . . But all ballast does is keep the 2 axles and 4 tires in ground contact and if 2 axles and 4 tires are in the exact same spot . . . More ballast on the rear increases the rear axle load but thats the ballast doing it. But I see no way for front axle load to be reduced by ballast.
If your analysis is correct then why do the rear tires come off the ground when you overload the FEL.
   / You need balast or you will trash your front axle!!!! really? #43
Great question? You've added greater weight load to the front axle so the rear wheels are no longer meeting the tractor definition of 2 axles and 4 wheels in ground contact. So adding ballast in the rear allows that definition to again work. HOWEVER . . . the weight on the front axle doesn't reduce if 2 axles and 4 wheels are in ground contact and you add 400 pounds ballast to the rear.
Simply stated . . I define the ONLY safe way to operate the tractor is with 4 wheels and 2 axles in ground contact so all stress changes made that violate that rule need to be corrected first. At that point adding weight to the front axle and tires is adding weight to those. If 500 more pounds or rear ballast get added and no change to 4 wheels and 2 axle contacts . . . you have not reduced the front end axle strain . . . unless you want to create a way you can have "more than ground contact".
Jmho
   / You need balast or you will trash your front axle!!!! really? #44
I did a small scale test using a toy loader and a kitchen scale. Let's pretend the lift capacity of the loader is 1 pound.
Machine weight with no ballast 17.1 oz
Front axel weight with no ballast 10.3 oz
Front axel weight with bucket loaded to tipping load with no ballast 27.1 oz
Tipping load was 9.2 oz. this is pretty accurate since most tractors will tip before maximum load is reached.
Now I added 11 oz of ballast.
New front axel weight 4 oz.
weight of front axel with previous tipping load 21 oz.
Here is the problem, I can now lift much more.
Weight of front axel with 1 pound load 34 oz.
weight of front axle with the ballasted tipping load 70.oz
Weight of tipping load 41 oz.
   / You need balast or you will trash your front axle!!!! really? #45
One more attempt to simplify. The basis of my opinion is the definition of how leverage and pulleys and levers work. Its about distance and movement combined to alter weight locations. But if all 4 wheels and both axles are in ground contact . . . Movement doesnt exist . . and without movement, levers and fulcrums and pulleys can't work.
Jmho. . . . I'll let others present their side.
   / You need balast or you will trash your front axle!!!! really? #46
Jmho
If you load the FEL till it raises the rear wheels off the ground you have reduce the weight on the rear tires, then add rear weight the rear wheels go back down. Now continue adding weight to the rear and when enough is loaded the front wheels will lift off the ground. Now the only way that can happen is if you reduce the weight on the front axle. Otherwise the front tires would not come off the ground.
The simplest way to look at the math/physics is to consider the "additional" load on the front axle as a function of loads on the front loader and loads on the three point. This will be the load above and beyond the basic contribution of the tractor weight. When perfectly ballasted, let's say there will be no more load on the front axle than usual. For that to happen:
F * LF = R * LR
where:
F is the load on the front loader
LF is the length from the front loader's load to the rear axle
R is the load on the three point
LR is the length from the three point's load to the rear axle
That tells us that the rear ballast load must be:
R = (F * LF)/LR
As an example, say I lift 1000# in my L3200. LF is about 7'. LR is about 4'. That means:
R = (1000 * 7)/4 = 1750#
In other words, it would take a heck of a lot of ballast not to add additional load over the front axle. More ballast than the load itself!!!
Much more ballast and this was exactly my point. :)
   / You need balast or you will trash your front axle!!!! really? #48
   / You need balast or you will trash your front axle!!!! really? #49
You don't need movement to balance out weight.
Jmho
Axle - there are different degrees of "gound contact". The term that is generally used is called "ground pressure". Adding weight to the 3pt hitch reduces "ground pressure" on the front wheels all things being equal.
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A56435)
BOSS 990 Fuel...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
Enerpac RCS302 30-Ton Hydraulic Jack, 5" Tall (A59076)
Enerpac RCS302...
Turfco Mete-R-Matic XL Towable Golf Course Drop-Style Topdresser (A55973)
Turfco...
2009 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A58017)
2009 PETERBILT 387...
