You need balast or you will trash your front axle!!!! really?
   / You need balast or you will trash your front axle!!!! really? #31
I'd don't mind admiting that I'm a bit confused by some of the logic being used to support viewpoints.
A tractor is not a teeter-totter. It would seem the discussion of ballast is based on a 2 axle scenario but statements of opinion are too often built based on a single axle scenario imo.
Here is an example. The goal of any tractor is to keep both axles in some form of contact with the ground. If both axles are in contact with the ground . . then leveraged weight outside the tractor's axles (forward of front axle and rearward of rear axle) . . Is still on that axle. That is not true with a teeter totter because the ends can go below axle center . . But on a 2 axle unit like a tractor where both axles are in contact with the groud . . . Leverage can not make the "plane extend lower than axle height".
You can definitely overload either axle or both axles . . . But unless you are allowing an axle to come off ground contact . . You can't alter the other axle's load that I can see.
Maybe my viewpoint is flawed somewhere . . But ballast is designed for one thing and one thing only . . to keep both axles in contact with the ground. A teeter totter or a roller & lever can use ballast to shift weight loads because it is a single fulcrum point. A tractor if being used correctly is a dual fulcrum/axle point.
When I load my FEL the front axle becomes the pivot point and as the FEL loads up the down force reduces the load on the rear tires. If continued to load the rear tires will come off the ground and the load of the FEL and the weight of the tractor shifts to the front axle.
The same applies to the 3pth. If the 3pth is overloaded the front tires come off the ground and all the load is on the rear axle.
Adding weight to the 3pth reduces the load on the front axle just not to the point of lifting the wheels off the ground. This makes the load on the front axle less and when you fill the FEL the load is transferred to the front axle but less load is applied to the front axle due to the counter force on the 3pth and rear axle.
The end result is less load on the front axle compared to not having ballast on the rear axle.
Well said.
   / You need balast or you will trash your front axle!!!! really? #33
//The discussion at hand is weather adding wheel weights or filling the rear tires will lighten the load on the front axle. The short answer is that it will not lessen the magnitude of the load on the front axle, but it will change the weight distribution between the front & rear axle. //
Tadah!
I put ballast on my tractor because the rear wheels would come off the ground with a big load, even though the rears are filled.
   / You need balast or you will trash your front axle!!!! really? #34
This discussion come up every year or two. I will assure you that any weight put on the 3pt unloads weight off of the front axle. Even 1 pound. How much it unloads is a function of how much the wieght on the 3 point is and how far back it is from the centerline of the rear axle.
Lets use an absurd example to illustrate my point. hitch a boom pole to your 3 point. Only now this boom pole is 100 foot long. How much weight on the end of this 100 foot boom pole do you think you would need to lift the front axle off of the ground when your loader bucket is full of wet sand? Not much I would wager. In fact in the boom pole was made of steel, I think you front axle and loaded bucket would be off of the ground without any weight on the boom pole. Now shorten the boom pole to 50 foot long. Would the loaded bucket and front axle stay on the ground? Maybe? how about 25 foot long? Now we would likely have to add a little weight to the end of the boom pole to raise the front end right?
How much, I will leave to others to calculate, but my point is any and all weight you add to the 3pt, whether that is 1 pound or 1000 will take weight off of the front axle, as we have built a lever system with the fulcrum point the centerline of the rear axle, and the 3pt is definitely behind the rear axle center line. So the more weight we add, and the further we place it behind the fulcrum, the more weight it will remove from the front axle.
   / You need balast or you will trash your front axle!!!! really? #35
But your statement is talking about one axle not being in contact with the ground and that is not an operational mode of the tractor. Both axles need to contact the ground. Once that is done AND maintained . . . More ballast will not change tbe weight load pressure, on the front axle . More ballast allows you to increase tbe weight and presdure on the front axle . . but still more ballast won't reduce that front weight. Why? Because the tires/wheels/axles of both axles are in ground contact . . There is no place to shift it to. One axle . . . Yes . . . 2 axles . . No.
Jmho
   / You need balast or you will trash your front axle!!!! really? #36
This was proven using scales.
   / You need balast or you will trash your front axle!!!! really? #37
Jmho
I don't know how to tell you that you are wrong, other than getting your loaded tractor on a set of scales so you will believe it yourself.. BUT you are wrong..
   / You need balast or you will trash your front axle!!!! really? #38
Jmho
Please read again. Both wheels are on the ground. Just with ballast on the rear leaves less weight on the front axle. Same would be true if the ballast (full FEL) would reduce the weight on the rear axle and shift it to the front axle. All are still in contact but with less ground bearing pressure (less weight).
   / You need balast or you will trash your front axle!!!! really? #39
The simplest way to look at the math/physics is to consider the "additional" load on the front axle as a function of loads on the front loader and loads on the three point. This will be the load above and beyond the basic contribution of the tractor weight. When perfectly ballasted, let's say there will be no more load on the front axle than usual. For that to happen:
F * LF = R * LR
where:
F is the load on the front loader
LF is the length from the front loader's load to the rear axle
R is the load on the three point
LR is the length from the three point's load to the rear axle
That tells us that the rear ballast load must be:
R = (F * LF)/LR
As an example, say I lift 1000# in my L3200. LF is about 7'. LR is about 4'. That means:
R = (1000 * 7)/4 = 1750#
In other words, it would take a heck of a lot of ballast not to add additional load over the front axle. More ballast than the load itself!!!
   / You need balast or you will trash your front axle!!!! really? #40
Jmho
That is not how the physics work. There are loads on the front and rear of the tractor, plus the tractor's weight, all pressing down. That is counteracted by the combination of the ground pressing back up with a force (or reaction) on the front axle and a force on the rear axle (either of these can be zero if the axle has lifted and the math/physics still works). They all have to add to zero if the tractor is stationary (i.e., not going airborne and not sinking into the ground). Any combination of the front and rear axle reactions that satisfies physics will do that. The exact combination is determined by the distances between the various loads and reactions, which is how leverage comes into play.
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A58017)
2019 PETERBILT 579...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
(2) METAL & WOOD STORAGE RACKS (A52708)
(2) METAL & WOOD...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A58018)
2020 INTERNATIONAL...
2019 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A58018)
2019 INTERNATIONAL...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
