YM336D - Started knocking loud while tilling
/ YM336D - Started knocking loud while tilling #281
Good Job.. I have been pulling for you.
/ YM336D - Started knocking loud while tilling #282
Well, I put it all back together and I could swear it blew another head gasket! I made a long video of it running. It sounds like it blew again somewhere around the 1 minute mark.
Tractor rebuild startup - Third time's the charm.. hopefully - YouTube
I'm at a loss as to what more I can do. Unless the valves are not opening when they should, I don't see anything else which even could be wrong with it.
Not so sure, dosent look like what happend in the bottle the first time. When its cold from cold start up can you see bubbles in the bottle?
It sounds like an injector quit firing.
/ YM336D - Started knocking loud while tilling #283
it definately sputtered, died down a touch then came back up. possibly the pump or and injector playing up or some crud dislodged and was ingested? it did smoke a touch when this happened but appeared to sort itself. if you are happy with its running now give her a bit of work to do :thumbsup: dont pussyfoot around with her either;)
/ YM336D - Started knocking loud while tilling #284
That sounds good, I would not worry about the smoke in the exhaust..glad you have it going, you defintely deserve a break for a spell? Check the oil and the valve lash..
/ YM336D - Started knocking loud while tilling #285
Well it sounded like the compression was at least equal this time from the little bit we heard while it cranked before firing up. :thumbsup:
/ YM336D - Started knocking loud while tilling #286
Take a breather and enjoy your tractor.... just run it, put on your ipod and don't listen to it ...just drive it.
/ YM336D - Started knocking loud while tilling #287
Sounds like an injector is acting up. That will make an engine sound like it's coming apart.
/ YM336D - Started knocking loud while tilling #288
Hi Domush
Just wondering if you had a chance to run the tractor a bit ?
From Connecticut !!
Is the loader you saw off a 3cyl ford or a 4cyl ford ?
/ YM336D - Started knocking loud while tilling #289
Sometimes my equipment (336D) and others suffer from too much maintenance and too much knowledge. I agree with the others , run it and enjoy. 336D is a great machine. I've had mine 5 years and it is tops.
Joe
Sorry for the slow update, everyone. Life has been busy and I just finally got around to borrowing an actual implement to test the PTO with (I don't own a single implement yet!). I borrowed a 6' finish mower and mowed my and a friend's yard with it.
At first it was doing the clackitty-clack you all can hear on the final startup video, but after mowing for a while I noticed the clacking had gone nearly completely away. It was beginning to sound like a modern kioti engine. The exhaust note (that big, v-8 chevy truck-like note) is now prominent (I never even heard it before the rebuild) and the smoke which followed me all the way to my neighbor's house is now gone even under load! It now has that slight smoke when I throttle it under load, but never any other time (that I can easily discern, at least)!
I think this finally completes my rebuild thread. The tractor starts immediately, no longer smokes, lost that awful clacking sound and pulls a 6' finish mower in gear 6 (out of 9) without a single hesitation!
Next up, my "Front end loader adaptation and install" thread!
Photo lovers, don't despair, I have some random pics for your eye candy enjoyment!
A horse head I made for my local horse club (stainless steel)
Brutus and Maggy
What a moth in Kentucky looks like!
What a car in Kentucky looks like
What people in Kentucky call "hunting", then proceed to tell you "I bow hunt for the challenge". :confused2:
Lexington, KY horse ranch -- Otherwise known as "My future home after winning the lottery I never play" :drool:
Lastly, a HUGE thank you to everyone who has helped me out in this thread. You all made this rebuild a great learning experience, and made a fellow Yanmar owner a smarter guy for it.
Cheers!
/ YM336D - Started knocking loud while tilling #291
Thanks for the update. Sounds like it was just burning off the last bit of oil from assembly as well as seating the rings. Hope you dogged it good to seat them, but it sounds like it. Smoke at full throttel or throttleing up is normal.
And yess it should have that deep not by the exhaust, even my little 2000 has it by the pipe, if you can hear it over the banging 2cyl! Im sure your injectors maybe have freed up a bit, did you use any treatment?
And thats my type comedy. YOu get hounded for no pics so you include some total random pics with the post. And you know what i looked and read 90% of them!!!
/ YM336D - Started knocking loud while tilling #292
Great Job DoMush-
Now to the task of finding some seat time........
/ YM336D - Started knocking loud while tilling #293
We always like good results sometimes takes patience which no doubt you have plenty! ;)
Btw Domush I took some pics of my Koyker loader mount which should be fairly easy to duplicate. Will at least give you a platform from which to make another loader fit your machine let me know if needed.
/ YM336D - Started knocking loud while tilling #294
DoMush
I can get some pics of my brackets on my Yanmar loader. Its a solid brace under the middle of the tractor and a bracket up front-
let me know. Did the loader you bought come with a seperate pump ? Should be up front if its still together....
YES, please do post some loader photos! Especially wanted are specific mount points and how the pieces are attached together. I'll be making this from scratch, so specifics are really important to me.
I made my FEL thread, so please post em here: Ford loader mod and install on YM336D - TractorByNet.com
/ YM336D - Started knocking loud while tilling #296
Probably not giving out any prizes or anything but if they were this thread should win all around thread of the year. It has been very educational, very enjoyable, very sad, now very happy, very well documented with pictures. Even though I may never get to meet you personally Domush, I feel like I nearly know you and have gained great respect for you. I will be looking forward to your loader installation. :thumbsup:
/ YM336D - Started knocking loud while tilling #297
I concur.
/ YM336D - Started knocking loud while tilling #298
Domush,
I followed the post and along with you learned a lot from car doc and others. Great job keep her running. You best pick up that lotto ticket that horse farm looks wonderful. To all who helped domuch you all make TBN a good place to spend time.
/ YM336D - Started knocking loud while tilling #299
another well done all the way from Australia. good to see you perservered with her and came out the victor. it probably wouldnt hurt to give her a good load up and workout again to ensure the rings have bed in properly. i also would advise running a 300:1 ratio of 2 stroke oil in it as this will help lube up the pump and injectors which i do with my landcruiser and both tractors.once again well done and happy yanmaring :thumbsup:
/ YM336D - Started knocking loud while tilling #300
What a remarkable thread of highly capable people and the true grit of Domush.
Thanks to all for such a fine thread with a happy ending.
