YM336D bad knocking engine
/ YM336D bad knocking engine #61
You're probably correct CoyPatton. Again, I can't picture the size of the nut in relation to the gap available to fit through and roll around in. You would certainly know better than I. The scope is for sure the safest and best route to go. Hadn't considered that.
I surely hope not!:eek:
/ YM336D bad knocking engine #62
I have looked and can稚 see a thing. Bore scopes aren稚 too expensive, so I may add to my growing tool set.
Sixdogs, yes I did turn the cam. I moved it thinking I could continue checking the valves. When I felt a little tension I stopped, reversed a little and resumed probing with a magnet.
Don't turn it anymore, you probably realized that. You can scar up that cam lobe.
John Deere 5525 (A60462)
John Deere 5525...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
set of 4 tractor trailer tires Roadforce (A61307)
set of 4 tractor...
2019 Big Tex 10PI-20BK4HDIR 5 Ton 20ft T/A Pipetop Equipment Trailer (A59230)
2019 Big Tex...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
