YM3110 question
/ YM3110 question #1
paulBurns
Carroll Co Tn
Ym3110
This week I bought one and do not have a manual as of yet. I used it several hours today with a tiller and could not get the tiller to go to a set position easily. Rasing the lift lever resulted in the tiller not responding for a while then it would go all of the way up not just a little. Same thing on the lowering. I could not set the depth with any accuracy at all with the lift lever. Thanks for your thoughts.
/ YM3110 question #2
sounds like you don't have position control on your tractor, some don't- either up or down, no inbetween
/ YM3110 question #3
Unless you know for sure when the last time the hy/trans pickup screen was cleaned and fluid changed, I would start with that. A dirty screen can cause the erratic behaviour you describe. You should be able to tap the lever up or down and move the implement by fractions of an inch.
2010 Cadillac CTS Sedan (A61574)
2010 Cadillac CTS...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
