YM3110 question
/ YM3110 question #1
paulBurns
Carroll Co Tn
Ym3110
This week I bought one and do not have a manual as of yet. I used it several hours today with a tiller and could not get the tiller to go to a set position easily. Rasing the lift lever resulted in the tiller not responding for a while then it would go all of the way up not just a little. Same thing on the lowering. I could not set the depth with any accuracy at all with the lift lever. Thanks for your thoughts.
/ YM3110 question #2
sounds like you don't have position control on your tractor, some don't- either up or down, no inbetween
/ YM3110 question #3
Unless you know for sure when the last time the hy/trans pickup screen was cleaned and fluid changed, I would start with that. A dirty screen can cause the erratic behaviour you describe. You should be able to tap the lever up or down and move the implement by fractions of an inch.
CASE IH MXM175 MAXXUM TRACTOR (A64280)
CASE IH MXM175...
Tufline PT 12' Box Blade (A64119)
Tufline PT 12' Box...
2004 CATERPILLAR 242 SKID STEER (A64279)
2004 CATERPILLAR...
2021 CATERPILLAR 306CR EXCAVATOR (A64279)
2021 CATERPILLAR...
2019 Nissan Maxima Sedan (A61574)
2019 Nissan Maxima...
2020 KOMATSU D51PX-24 CRAWLER DOZER (A64279)
2020 KOMATSU...
