3-Point Hitch YM2500 Plow Light Wiring
   / YM2500 Plow Light Wiring #41
My work light is wired to the fuse box. Positive to the Ign. key Switch. Brn. wire 5A .
Then ground it to the frame.
   / YM2500 Plow Light Wiring #43
I don’t know why my phone is doing this. I’ve logged out, logged back in, and turned my phone off and back on. Still doing it. I don’t have a computer.
ok, we'll just have to live with it. LOL Maybe it's the browser on your phone? Try switching to a different one? ... no idea really.
I use a computer. I don't like using the phone for internet. Tiny screen and my fingers are way too big for the tiny touch pad to punch out the words. When my last lappy-top died, I was stuck with only the phone for 3-months. It was grueling to say the least. Got tired of dead laptops every 3 years. Went back to a desktop workstation that is a killer gaming machine too.
   / YM2500 Plow Light Wiring #44
I can't hardly type from injury's or see for that Esp. without the Spectacles on! I was looking at a Org. paper Dia. And then seen my copy on the computer. Here it is! Cell ph. that's not going to happen. My model has super large #'s to make sure I see them and hit the right # for that matter. It's a 15Amp. they came off of for power. Then use the Grn on the light to ground it. On this Dia it shows the work light on the Upper R. and how it's wired.
  • Yanmar wiring diagram0001.pdf
Thank You!!
Is this the wiring diagram for a YM2500?
   / YM2500 Plow Light Wiring #46
Thank You!!
I had already posted the wiring diagrams for you. Scroll back in the messages.
   / YM2500 Plow Light Wiring #47
Thank You!!
No I think it's a Yanmar 336. Many Hrs. on a Fredricks refurbished YM2500 and just the basics on that Tractor! My early YM2000 is actually the same or really close if I recall. The Dia. has all the bells and Whistles on it is why I posted it. Your just after the Work light.
[emoji[emoji6][emoji6]][emoji6][emoji[emoji6]]" data-quote="careyo[emoji6]" data-source="post: 0" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">
No I think it's a Yanmar [emoji6]. Many Hrs. on a Fredricks refurbished YM[emoji6][emoji[emoji6][emoji6]][emoji[emoji6][emoji6]] and just the basics on that Tractor! My early YM[emoji[emoji6][emoji6]][emoji[emoji6][emoji6]][emoji[emoji6][emoji6]] is actually the same or really close if I recall. The Dia. has all the bells and Whistles on it is why I posted it. Your just after the Work light.
Thank You!
The work light is getting v back feed through the ground. Gotta let my mechanic see what’s going on with it.
***UPDATE 12-16-2024***
PROBLEM SOLVED! The plow light is now fixed and working exactly like it should.
I had roughly 8 hours in it with about 4 packs of blown fuses and couldn’t get it to work.
My mechanic had it properly working within about 8 minutes.
The switch on the plow light was wired wrong from the factory! They had 2 grounds going to each side of the switch. My mechanic had to do some cutting and splicing and route the hot wire into the switch. That’s all there was to it!
2014 Kenworth T370 Single Axle Dump Truck, VIN # 2NKHHM7X6EM419999 (A57453)
2014 Kenworth T370...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
MASSAGE CHAIR (A58214)
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56438)
Ditch Witch 6510A...
