3-Point Hitch YM2500 Plow Light Wiring
   / YM2500 Plow Light Wiring
What do y’all think about the reflectors on the rear fenders?
They’re a little bigger than the original OEM “Cateye” brand reflectors, but I still think they help bring out the little Yanmar’s beauty!
@Travis_R My condolences. That's a tough and painful disease to have to deal with. I know that there are some immune modulating therapies available; anti-TNF agents, and JAK inhibitors;
I think that the human immune system is not particularly well understood at the moment, and many autoimmune diseases do not have truly specific and effective therapies, but not for a lack of effort on many people's parts.
All the best,
Peter
Thank You. I agree with you 100%. I can honestly tell you that after messing with the plow light on the tractor for most of the day yesterday, I literally cried in my bed last night because I was hurting so very bad. Excruciating pain. I thought I was gonna have to make a trip to the ER and get Morphine and Toradol shots. I hurt every single day. It NEVER goes away. The more I try to do, and stay active, the more I hurt.
   / YM2500 Plow Light Wiring #34
Return the light to the eBay seller.
Run out to Harbor Freight and get this. Then the install is PAINLESS.
[emoji6][emoji6]" data-quote="bmaverick" data-source="post: 0" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">
So you’re thinking the plow light is the problem, and not the v wire on the tractor? I’m just trying to understand. I’m not good at this stuff.
   / YM2500 Plow Light Wiring #36
You need to use the forums with a computer. Your phone is doing very strange things here. LOL :ROFLMAO: 🤪:giggle:
   / YM2500 Plow Light Wiring #37
Two wires to the R. of the steering wheel. Toggle switch +/-. Was on it when i bought it in 08. Still works AIS.. The headlight switch is on the L. front of the Dash. I've seen it had a rubber factory insert were the Red light switch was moved to from were the work light is now. Red button next to the Turn signal is the Horn. Red Button that came up on a thread.
   / YM2500 Plow Light Wiring #38
I honestly think your hooking up wires wrong. A basic light either has 1 wire and uses the mounting device for the ground, or has 2 wires, one being a ground and one being the hot. This fixture is just wired weird. A green wire with yellow stripe is universally considered a ground wire.
   / YM2500 Plow Light Wiring #39
Org. location of the Head light switch. You can see the opening were it was moved to on mine.
The Brown wire on the light is ground. Green is low beam, White is high beam.
I think something is going on with the 12v wire that goes to the ignition switch.
Does anyone have a wiring diagram of the key switch? I may need to run a new wire.
The ignition switch that’s on there now is an aftermarket switch made in China.
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
Case Skid Steer Backhoe Attachment, S/N 391998, 20" General Purpose Bucket, Asset# 71 (A59076)
Case Skid Steer...
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
LOT: (2) Cargo Van Shelving Units, (2) Steel Shelves (A59076)
LOT: (2) Cargo Van...
2305 (A58376)
2305 (A58376)
