YM2500 HYDRALIC LEAK
/ YM2500 HYDRALIC LEAK #1
Travis_R
Livingston Parish, LA
Yanmar YM2500
Hey,
I got the tractor yesterday. Hour meter shows 852 hrs. There is a small hydraulic leak thats coming from this "valve" looking thing under the seat.
When you pick up on the position control lever, It turns a rod that goes under the seat. The rod is connected to linkage, which in turn pushes the "valve" in. When you let the position control lever down, the "valve" comes out.
The "valve" is like a very small "piston" looking mechanism.
Standing from the rear of the tractor, It is directly behind the "spring" that is under the seat. The spring and valve are in the same "line" as the tractor's 3-point hitch "toplink".
The "valve" (that pushes in and out) has a nut or bolt with a rubber gasket in it. The rubber gasket is whats bad. Its almost like the rubber gasket is mounted inside the nut or bolt (which ever it is).
This is very simple to see when you lift the seat up. Is is hard to explain without any pictures though.
I looked at Fredricks' and Hoye's website but couldn't find a picture of what I needed.
Anyone confused yet?
Thanks,
Travis R
P.S.....I really love my tractor. Not because its new, but because its the size I need.
/ YM2500 HYDRALIC LEAK #3
I would assume it's leaking where I pointed to in the attached picture. I had a leak there on my YM1700. Simple O-ring fix. That is if the two tractors are made about the same.
/ YM2500 HYDRALIC LEAK #4
Travis_R said:
Hey,
Thanks,
Travis R
Travis, it's not a gasket, it's an oil seal, very common & easy to replace.
Danny
Inspector507,
THANKS.
That is EXACTLY the spot where it is coming from. But from the looks of it, I don't believe that its an o-ring. Its more like an "oil seal", like 1danny said. I guess thats one difference between the YM1700 and YM2500.
Danny,
THANKS.
Do you have this "seal" in stock? How difficult is it to replace? Can I just un-screw the bolt/nut and replace the seal inside, or does the new seal already come pressed inside a new nut/bolt?
Will I loose enough hydraulic fluid to have to go out and buy some?
I have a 30 day parts warranty with the tractor (no labor). I'll call the dealer tomorrow and see what he says. If he can't get the seal or doesn't want to warranty it (not wanting to jump the gun), then i'll definitely buy from you Danny because you are the first dealer that replied to my problem.
I will soon get a Service and Parts manual(s) for my tractor.
THANKS VERY MUCH,
Travis R
THIS IS WHAT T.B.N. IS ALL ABOUT.
/ YM2500 HYDRALIC LEAK #6
I have the seal, but you should get your dealer to replace it, and yes you have to remove the old seal and replace it with a new one.
Danny
Thanks very much Danny.
By the way, what in the world is that "valve" looking thing called, anyway? I need to know what to tell the dealer the seal is for.
Travis R
/ YM2500 HYDRALIC LEAK #9
It's most likely oil seal # 194151-45810, $3.66 at Hoye. It appears almost every Yanmar uses the same one.
Hey thanks a lot ya'll. It is truly appreciated. I'm sure it isn't going to be anything to get it fixed.
Thanks again,
Travis
I think its fixed.
I want to say a Special thanks to Danny Parker with Parker Equipment Company (www.peq.com), Inspector507, and normde2001 for aiding in getting my problem solved. THANK YA'LL.
I got the seal from my dealer. He sent it to me at no charge because the tractor has a 30 day parts warranty. He didn't give me any hassle over it, either. UPS delivered the seal yesterday (2-16-07). It was here sooner than what I thought it would be. That was the easiest seal I have ever changed. The old one popped right out, with the persuasion of a small flathead screwdriver, and the new one went right in, using a same diameter socket as the outside diameter of the new seal. I put some "never seize" on the inner and outer diameter of the seal (to help out the installation process) before I put it in.
I did notice something with the old seal out (and before I put the new one in) that oil came out when I manually pushed the control valve in. I don't know for sure (?) but their may be another seal or something else "farther back" inside the control valve assembly that may need replacing (?) Hopefully the seal that I replaced took care of the problem though. But should oil be coming out BEHIND (up inside the housing) the oil seal when the control valve is pressed in?
Thanks,
Travis
NOPE. ITS NOT FIXED. Its still leaking. There must be some other seal or something behind the oil seal (up inside the housing) that I replaced.
I bought a Parts Manual from Hoye the other day. It shows there might be some sort of "copper packing sealing washer" inside there somewhere(?). Maybe(?) that needs replacing(?).
I think that my most concern is not knowing where to start taking the thing apart TO get it fixed.
Please help. Spring is just around the corner and I need to get this leak stopped.
Travis
/ YM2500 HYDRALIC LEAK #13
The copper washer seals between the push rod holder & the valve body. There are not internal seals, just a close machine fit. The valve body is probably warn to a point where it needs replacing. I can supply you with an OEM or aftermarket one.
I have got to ask this question. Its been on my mind.
Why would the hydraulic control valve body need replacing with only 853 hours on the meter?
If thats what it needs, then i'll have to get it.
Travis R
/ YM2500 HYDRALIC LEAK #15
Can't comment on whether the part needs replacing or not as I haven't seen it.
But keep in mind that the hour meter is probably like most of the other yanmars and is a 3 digit hour meter. That 800 number could just as easily be 1800, 2800 or more. Probably not but possible. I'm not sure when the 2500 was made but it's probably at least 20 years old. Good luck.
/ YM2500 HYDRALIC LEAK #16
I believe the seal is really only designed to wipe the shaft clean before it enters the valve body. It does not hold the oil in. A leak around that seal is usually only a symptom of an internal problem. Like Len says, they are very rarely repairable as the housing is normally worn down. The new (and used) valves are readily available now. Just ask your dealer buy you a new one and you will be ready for spring. :)
Aaron
Parts@HoyeTractor.com
(940)592-0181
/ YM2500 HYDRALIC LEAK #17
I'd assume it is warn ,because the three point was raised & lowered a lot. I've sold quite a few of them, so it is a common problem.
Ok, I called the dealer today. I have to bring the tractor back to him. They're gonna fix it free of charge (and a labor warranty didn't even come with it). I can't ask for anything better. He told me before I bought the tractor that "We're not out to get anybody", and I do believe him after this. Thats the way every dealership should be.
So as it stands now, Manning Enterprises in Franklinton, LA does stand behind their tractors and Services what they sell. I'm satisfied.
TO lens12,
If they wasn't gonna warranty it. I would have bought the new valve body from you. Thanks a lot.
Thanks to all,
Travis R
/ YM2500 HYDRALIC LEAK #19
Thanks for your intentions.
Here it goes again.
Brought tractor in. They took used valve body off of another YM2500, which I agreed to. It stopped leaking fluid. I asked dealer if we should "hook-up" an implement to see if it will leak. He said no. "If its gonna leak, its gonna leak now". I said ok and headed 90 miles back home.
Got home and hooked up my light duty King Kutter rear blade to work the driveway. Everything was going good. Killed tractor with implement still in the fully raised position. What do I see? IMPLEMENT SLOWLY DROPS ALL THE WAY TO THE GROUND!! I got furious. It never did this with the Leaking valve body!
I called the dealer right then. I was firm, but nice. I told him that I was getting aggravated with all this, but did appreciate them working with me on the matter. Mechanic said to bring it back next Saturday that its gonna get a brand new valve body on it. He was really nice. It seems that he knows where i'm coming from. The tractor OR new Sitrex finish mower hasn't been right since the first day I had it.
I just wanna say that they Are trying to work with me. They would have installed a new valve body on it the first time, but didn't have any (even though they had a week to get it) in stock. I'm just tired of the drive up there and the fuel that it takes to make the trip.
Before I bought it, I didn't think that I would have to worry about the tractor after seeing the "Serviced By (*name*) at Fredricks Equipment" decal on the air filter housing, even though thats not who I BOUGHT it from, but its where it CAME (re-conditioning process) from.
I'm gonna take my Bush Hog Squealer (my heaviest implement) cutter up there with me next Saturday. I'm gonna drive the tractor around the parking lot with it and see if everything "holds up" when its fixed.
I also notice/want to mention that as the tractor gets hot, the hydraulics make a "squealing" noise. I've checked the oil though and its at the full mark every time.
I think/hope everything will eventually get worked out/fixed. The tractor is strong and starts EXCELLENT! But I gotta say, Times like these is where I miss my Mahindra, Dearly.
I sure hope this grass season isn't gonna be troublesome because it ain't lookin' too good fer me right now!
Travis R
Athey 7-12D Force Feed Loader (A62679)
Athey 7-12D Force...
2017 Hino 155 16ft. Box Truck (A61573)
2017 Hino 155...
2015 Ford F-150 Ext. Cab Pickup Truck (A61573)
2015 Ford F-150...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2025 32in. Tilting Bucket Mini Excavator Attachment (A61572)
2025 32in. Tilting...
2014 Link-Belt 350X4 Hydraulic Excavator (A61572)
2014 Link-Belt...
