YM226D Pwer Steering Unit
   / YM226D Pwer Steering Unit #1
DrewYM226D
Western Pennsylvania - Near Pittsburgh
YM226D, Cub Lo-Boy 154
Hello, I am a new member but I've been reading posts for some time. My YM226D has a power steering unit and I know these were not standard. The valve has a small hole or crack. I'm not sure exactly since the guy I bought it from had some kind or gunky-goo over the spot to slow the leak. It looks like the valve is aluminum and it has "PH-5001" marked on the side. Does anyone know if this is a Yanmar or other after market unit? Anyone think it can be repaired? Thanks, I appreciate the help.
   / YM226D Pwer Steering Unit #2
can you post a picture of the area ?
   / YM226D Pwer Steering Unit #4
Welcome Drew,
I think you'll find some pretty good parts support up in that area.
Bruce
   / YM226D Pwer Steering Unit #5
Perhaps the easiest way to repair it would be to run to the parts store and pick up some new gunky-goo? /forums/images/graemlins/tongue.gif
   / YM226D Pwer Steering Unit #6
Depending on where it is in the casting or what material it is , there are lots of ways to fix a problem. More info please........
   / YM226D Pwer Steering Unit #7
I don't know if it is a Yanmar unit or not. A couple styles were used., but parts aren't available. A do have a complete Yanmar powersteering assembly . If it is disassembled it may be possible to have it welded.
   / YM226D Pwer Steering Unit #8
I have repaired many of those PH units, there is two O-rings inside that need to be replaced. They are difficult to get to, but at least it is not expensive to do.
   / YM226D Pwer Steering Unit #9
Len;
Will the power steering assembly you mentioned for the 226 fit the 1820D you sold me?
If so what is the cost of the unit uninstalled.
Tom Hosack
OK, here's a pic that shows the unit. The little piece at the top that shines is where the red gunky-goo is. I hope this picture helps. Thanks again. You guys are great!
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
10' WROUGHT IRON SITE FENCE (A51248)
10' WROUGHT IRON...
1997 MONON 102" X 53' T/A VAN TRAILER (A51247)
1997 MONON 102" X...
Generac Generator (A51691)
Generac Generator...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2004 Wabash National 28ft Van Trailer (A51692)
2004 Wabash...
