Comparison YM2010 and YM2310 differences
/ YM2010 and YM2310 differences #1
Simelmoe
North Alabama
A
Does anyone know if there are any differences in the two other than displacement and rear wheel size? Mainly curious if the trans and engine block were the same.
/ YM2010 and YM2310 differences #2
Not a definite answer but I can tell you according to Hoyes parts they both use the same main bearings, rod bearings, pan gasket, valve cover gasket, valves. Of course sleeves, pistons, and head gasket are different.
Both transmissions use the same transmission gasket and power shift valve gasket.
I also notice Tractor Data gives the 2310d a weight of 1984lbs and the 2010d 2060lbs. Surely some bad information there??
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2008 THE MACHINE CO. THAWZALL H250 HEATER TRAILER (INOPERABLE) (A67714)
2008 THE MACHINE...
QA Mini Pallet Forks (A64912)
QA Mini Pallet...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
