YM2000 vs. YM2001
/ YM2000 vs. YM2001 #1
mostrander
I've been looking to buy a yanmar for some time now, a friend has let me use his YM2001 and it has plenty of power for my needs. I have found a YM2000 I would like to purchase. From my understanding the YM2000 is a 2 cyl and the YM2001 is a 3 cyl but the YM2000 has more torque? Is this correct?
Thanks,
Matt
/ YM2000 vs. YM2001 #2
Is it a 2001 or a 2001D ?? A 2000 is Listed at 22 hp 2 cyl. While the 2001D (4WD) is listed as 23 hp 3 cyl. The 2 cyl will have more torque. 3 CLY runs smoother than the 2 cyl
/ YM2000 vs. YM2001
I believe it is a YM2001 I know its not a YM2001D I'll have to find out for sure. I just want to make sure I get one that is comparible to my friends as his has enough to do what I need.
/ YM2000 vs. YM2001 #4
The 2 cyl will have more torque. 3 CYL runs smoother than the 2 cyl
YM2000 is rated 20 PTO hp, same as YM2001, at maximum working rpm. (2400 for both?)
You won't be giving up anything except smoothness. As I understand it YM2000 is stronger when rpms drop into the lower half of the rpm range, while YM2001 is sure to run smoother than the older YM2000 with its clank!-clank!-clank! characteristic sound.
Mostrander, listen to the sound file referenced from my sig (below). Compare that to what you recall of your friend's 2001. I would be interested to hear your comparison.
Bomag ProTack TW500 T/A Towable Asphalt Patcher (A64553)
Bomag ProTack...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
RAINBOW PTO 6" X 6" IRRIGATION PUMP (A64278)
RAINBOW PTO 6" X...
2016 Nissan Altima Sedan (A64557)
2016 Nissan Altima...
2009 Ford F-150 Pickup Truck (A64194)
2009 Ford F-150...
UNUSED PARBREAK SBT280 HYD STUMP GRAPPLE BUCKET (A65055)
UNUSED PARBREAK...
