YM2000 vs. YM2001
/ YM2000 vs. YM2001 #1
mostrander
I've been looking to buy a yanmar for some time now, a friend has let me use his YM2001 and it has plenty of power for my needs. I have found a YM2000 I would like to purchase. From my understanding the YM2000 is a 2 cyl and the YM2001 is a 3 cyl but the YM2000 has more torque? Is this correct?
Thanks,
Matt
/ YM2000 vs. YM2001 #2
Is it a 2001 or a 2001D ?? A 2000 is Listed at 22 hp 2 cyl. While the 2001D (4WD) is listed as 23 hp 3 cyl. The 2 cyl will have more torque. 3 CLY runs smoother than the 2 cyl
/ YM2000 vs. YM2001
I believe it is a YM2001 I know its not a YM2001D I'll have to find out for sure. I just want to make sure I get one that is comparible to my friends as his has enough to do what I need.
/ YM2000 vs. YM2001 #4
The 2 cyl will have more torque. 3 CYL runs smoother than the 2 cyl
YM2000 is rated 20 PTO hp, same as YM2001, at maximum working rpm. (2400 for both?)
You won't be giving up anything except smoothness. As I understand it YM2000 is stronger when rpms drop into the lower half of the rpm range, while YM2001 is sure to run smoother than the older YM2000 with its clank!-clank!-clank! characteristic sound.
Mostrander, listen to the sound file referenced from my sig (below). Compare that to what you recall of your friend's 2001. I would be interested to hear your comparison.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
