YM2000 2wd to 4wd conversion.
/ YM2000 2wd to 4wd conversion. #1
FixableUnknown
I have searched and can't find any info on a 4wd conversion. Is it possible? I have looked at the hoye parts diagram, and the front axle and driveshaft appear to be the only difference.
/ YM2000 2wd to 4wd conversion. #2
I would think the trans would be different too. That where the engaging lever and gears are.
/ YM2000 2wd to 4wd conversion. #4
It would be incredibly expensive even to buy a used assembly if you could find one. As mentioned you would also need a 4wd transmission. You would basically just be putting your engine in a 4wd tractor :). If you need 4wd I would just trade yours in on one.
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
Thanks for the info guys. I figured it was more involved than it looked.
