YM1802d-Electrical issue
/ YM1802d-Electrical issue #11
Always enjoy reading threads about battery and charging methods/systems, there are so many differing opinions.
In a former life I was an eng for HP. Had one assignment investigating different battery chemistry's. One of the battery types was LA batteries. Think that puts me in a place where I know a little about them and associated charging systems.
Not familiar with all the Yanmar electrical systems but do know a little about the one on my tractor. The alt is fairly small, about 15A max. Power out from the alt is A.C. and is rectified by the VR. The alt uses a permanent magnet and not a electromagnet field winding. This design is not unlike that found on most small engines like B&S, Kohler, etc. The only way for controlling voltage is to shunt power in excess of that needed to charge the battery and run lights, gages, etc. The alt is always putting out max power.
Now, for a nom 12V LA battery that is fully charged and has been at rest for several hrs the nom voltage should be close to 12.7V. Typ charge voltage via a alt/generator is ~ 14.25V. LA batteries typ have a fairly small self discharge rate, ~1%/mo of remaining capacity.
You really need to take some voltage readings. Battery with engine not running. With the engine running take readings at the alt output (remember output is A.C.) and at VR output and at battery terminals. I would expect to see a reading at the alt >14V. Should see voltage at VR output and battery the same voltage. Due to the small capacity of the alt, the voltage at the battery will vary depending upon how much of a load is being placed on the alt for charging and running any of the electrical acc. With lights off one should see a voltage higher than it was at rest and slowly increasing until it bumps up against the VR setting which should be about 14.25.
I could envision a VR design where when there is no battery attached, all the alt power being shunted to ground so there isn't any power available for the lights, etc. Could be all wet here but think this is a possibility.
/ YM1802d-Electrical issue #12
Are you troubleshooting the system, or just trying to test an electrical theory? If troubleshooting, you are going about it all wrong.
/ YM1802d-Electrical issue #13
Obviously, the battery is good enough to crank the tractor.
Alternator is putting out, voltage regulator *apparently* is not putting out.
Probably, the alternator is directly connected to the regulator, then the regulator to the fuse block via key switch, charging lamp, and battery via the starter.
Personally, I'd double triple check the ground on the regulator and then start checking continuity on the regulator outputs. Rationale: If the battery is staying charged, then part of the regulator is working. I would think that it's all or none, works or does not, so that makes me think grounds and wiring.
fwiw,
Keith
Hey guy's,
Here's what i have done. I've replaced the battery based on Clemsonfor's advice and check. The battery voltage this morning was 12.43vdc. Although the battery would not start the tractor and with the battery leads disconnected there were no lights or guages,
with the tractor running (1500rpm) and battery connected, the battery voltage is 13.99vdc. Far enough proof to me the battery is the problem. I have been an electrician since 1982 specializing in plc/ panelview programing, and a whole lot of instrument experience. I'm kinda ashamd to be asking for this kind of help.
THANKS A HEEP GUY'S AND/OR GAL'S FOR ALL THE HELP.
/ YM1802d-Electrical issue #15
Check your fuses. I cannot speak on the other questions about voltage at the alt or the voltage from the regulator.
Sorry, i see you got it figured! i had this thread open for a long time till i replied , and then saw all the ones since your last message and all the others who replied as well.
/ YM1802d-Electrical issue #16
Resting fully charged battery should be around 13.2 volts, charging can be up to 14.3 Volts without damage. But, lead-acid battery's will self discharge quick, so it is not uncommon to have one in the 12 volt range depending on age and condition, and temp.
Pretty sure a 12 volt battery in good condition is 12.65V, now if you just shut down it will read 13.??V untill it settles back down to the 12.7 level. If your reading 13+V on a battery that has been off a charger for hours or days i think it is unusual.
/ YM1802d-Electrical issue #17
We had a 1610-D that we had to replace the VR 3 x in 1 year, so.... you could have a bad regulator again...
/ YM1802d-Electrical issue #18
To me, it sounds like you have a bad regulator. And I've seen several vehicle electrical systems run lights and acc. directly off of the battery. So no battery-no lights. I think its mainly to allow for cheap VRs because the batt can withstand short voltage increase and/or shortages. Whereas the VR is more sensitive.
I think you've pretty much so zeroed in on that it's the VR.
/ YM1802d-Electrical issue #19
my YM14 pancake alternator puts out 20VAC, this is not enough to get a normal automotive regulator to output and extinguish the alt light. these alternators have lower outputs so the regs need to correspond as i found out.
/ YM1802d-Electrical issue #20
He finally said what the charging voltage is and what the resting battery voltage is. Obviously no prob other than bad battery. A fully charged battery should reach and hold 13+ volts.
2022 John Deere 5055E (A60462)
2022 John Deere...
MAHINDRA 4540 TRACTOR (A62130)
MAHINDRA 4540...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2012 FORD F-450 FLAT BED SUPER DUTY (INOPERABLE) (A60736)
2012 FORD F-450...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
