ym146 power shift
/ ym146 power shift #1
big85k51234
yanmar ym146 powershift
hello everyone, here is my first post on your forum. i have read alot of good post from here and decided to join:thumbsup: just bought a 146 yanmar and im looking to bring it back to life
/ ym146 power shift #2
Welcome aboard, what kind of shape is your 146 in?
/ ym146 power shift #3
Hi BIG....
I can help you with your YM146. My first question would be, do you have all the manuals?
There is an Operators Manual with all the general information; there is a Parts Manual showing all the parts; and there is a Service Manual that describes how to do the service and repairs. If you need any of these manuals, contact me.
/ ym146 power shift #4
Welcome to the board!
Several of us have the ym146 (or GT14) yanmars!
Get the manuals.....it helps running, repairing, and ordering parts.
Scott
/ ym146 power shift
well to start with the electrical is rigged very badly.. to crank it i have to hook up jumper cables and lift the hood where there is a light switch...not kidding. i have to flip the switch on and off to sorta crank it...the mower deck staysa running at all times unless i turn the mower off and unhook the belt. on a good note. whern im using the 3point hitch and a grader blade i made from scratch it is a beast..and the pto seems 2 work well also...there is just some major electrical issues and im guessing the pulley that runs the belt is messed up..also the belly mower is in pretty bad shape
on a side note i got the tractor for free from my uncle
/ ym146 power shift #7
Cool. Not sure Gary (Gjamtrac) has a spare wiring harness laying around, but he does have (usually) all three types of the belly mowers that were used on these tractors. I also will part with one of mine, most likely the YCM48 I have and am not planning to use.
I ended up buying a parts tractor to feed my other two machines once I got into them.
On a side note, one of my YM146's has a push button starter on it (ignition switch failed and the previous owner didn't feel like shelling out for a new one) and I thought my front PTO wasn't working all of a sudden. I recently realized that the key must be in the "run" position to allow power to lock up the PTO clutches. I stopped putting my key in the ignition because it was push buton start!
/ ym146 power shift
ok. yeah if the motor is running the pulley is turning weather the key is on or not.
/ ym146 power shift #9
The pulley on the PTO should not engage untill the switch is flipped up, but the ignition key has to be in the on position as well.
The PTO driveshaft is direct bolted to the crank pulley, so it will spin as long as the engine is running, but the clutch plates inside the PTO are what need to lock in order for the PTO pulley to spin. The locking is electronically actuated.
/ ym146 power shift
yeah the switch is defective more than likely..and the front pto is the one that runs the belly mower so im thinking there may be something wrong with that and the switch. but the rear pto doesnt engage until i push the handle forward so im thinking it still works correctly. my belly mower its self has seen better days and hardly cuts even the shortest grass. it wasnt equipped with the scalping wheel and seems like any chance it gets it wants to do a nose dive and tear up the yard.
it really is in poor shape but i just cant seem to bring myself to sell it cause i realize it has alot of potental.
/ ym146 power shift #11
Let us know which mower deck you have. If you search ym146 on this site you will find a thread that I put up when I first bought my 146. With Yannymans help I was able to find out which deck I had. Since that thread I have updated all my casings, bearings and pulleys.....my deck now is a quiet nice mowing machine. Be glad to help you where I can. The switch for the pto on these machines have been an issue from what I can tell. The PO of mine had put a new one on mine but still left the old one hooked up??? Works well so I have no plans to change it at this point. Good luck!
/ ym146 power shift
its a 48 inch deck that has the 2 wheels in back and 2 sliders in front 1 on each side. u can adjust the deck using a push pins stlye thing on the right side..i was looking at ur pics and i think its the same deck u have or had.
/ ym146 power shift #13
If it's a YCM48 I have one for sale, all rebuilt.
/ ym146 power shift
how much u want for it. just curious?
/ ym146 power shift
My buddy has a yanmar 4.5 ft tiller he said it has 1000 rpm and it might work on it. Any thoughts
/ ym146 power shift #17
Unless it is for the YM146 or other similar tractors, you might have a really hard time making it fit, or work. Here those who know about these things describe the YM146 as having a 2000 RPM, 15 spline PTO with a female end on the tractor. There may be some adapter you could rig up to make it work, but the only ones I know of are an 18 spline, 25mm adapter that fits Kubota B6000s and some (all?) of the little Mitsubishi/Satoh tractors, and the old 9N adapters that are 6 spline.
Between fitment issues, and running double the speed intended, the tiller might cause more headaches than it resolves. However, if the price is right, you may be able to swap sprockets on the tiller, if it is chain driven, to fix the ratios, and figure something out for the PTO as well. If you do, make sure to take pictures!
/ ym146 power shift #18
4.5' tiller I would guess is not a cat 0 implement and is probably way too heavy for the YM146. That's on top of the RPM issues, 3 link lengths and driveshafts.
4.5' x 12 = 54 x 25.4 = 1372mm.. That's big for that machine. The RS1000 (1000mm) tillers I don't think will work on the YM146's. Haven't measured mine yet (won't have it till Sunday, but it's fairly small.
/ ym146 power shift
ok guys..i found a john deere finish mower 231..its supposed to be 2000 rpm and 5 ft..any thoughts?
/ ym146 power shift #20
Not a Cat 0 implement. Way too big for a GT type tractor.
2017KENWORTH T270 SERVICE TRUCK (A65057)
2017KENWORTH T270...
2022 WESTERNSTAR 4700 CONCRETE MIXER (A67714)
2022 WESTERNSTAR...
20' CONNEX BOX (A67714)
20' CONNEX BOX...
2021 WEILER K560 KNUCKLEBOOM LOADER (A65057)
2021 WEILER K560...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
