3-Point Hitch YM1401D 3-point lift problem
/ YM1401D 3-point lift problem #1
hosejockey2002
Auburn, WA
Kioti CK20 HST
I just finished rebuilding my lift cylinder with new O-rings. I also drained and refilled the hydraulic fluid. After reassembling, the 3-point will only lift a couple of inches and then the lever returns toward the neutral position. The loader works fine, and cycling it up and down several times to purge any air that may be in the system did not help. Any tips or tricks to try before it comes apart again?
/ YM1401D 3-point lift problem #2
are you talking about the lever that you push to move the lift up & down that is moving to the netural position ? If so, can you hold the lever down & the 3 pt goes down / up ? If this is the case tighten the lever up or replace the friction washer. This is provided I'am undersranding what's going on .
/ YM1401D 3-point lift problem #3
The 1401 lift has no detent. You hold it, it lifts. You let go, it stops.
Yes, I'm talking about the lever that raises and lowers the 3 point. I pull the lever back to raise it, it goes up a couple of inches and stops and the lever returns to the neutral position. It didn't have this problem before I rebuilt the cylinder. Next time I get a chance I'll recheck the fluid level and clean the strainer.
Mine has three positions. You push it forward and it drops. You pull it back and it raises (you don't have to hold it). It stops when you put it into the middle position or when it is up all the way. I'll post a pic when I get a chance. Maybe it's different than most 1401s.
/ YM1401D 3-point lift problem #6
Well, maybe it's the 1510. Maybe it's a faded memory on my part. We haven't had a 1401 around in some time, but I was pretty sure the lift only raised when the lever was being held up....and when released it stopped working. Actually I suppose that would be a detent, as opposed to the typical setup wherein you pull the lever all the way up and the 3 pt. lifts to it's highest point. Sorry, it's late, I'm tired. Someone else with a 1401 will jump in hopefully.
/ YM1401D 3-point lift problem #7
If I remember :rolleyes:
There is an adjusment nut that control the movement of the neutral position
It points to the back of the machine & it has a spring on it, its behind the handle for raising & lowering it.
Raise & lower it while you watch and you can figure out witch way to adjust it.
I dont have a 1401 here or I would post a picture
Ernies Imports
/ YM1401D 3-point lift problem #8
From Ernie's description it is exactly like mine on the 1510D. With the positioning device with a spring and a sliding lock. I do not have a picture either, but can get one this morning (for me).;) My question would be will it continue to lift if the lever is held in the raise position, or will it stop. If it stops because it pulls the lever forward to neutral, then the adjustment is off. Try sliding that adjustment control forward an inch or so and see what that does.
Mike in Warsaw (Poland that is)
/ YM1401D 3-point lift problem #9
There should be a spring loaded detent to hold the lever in place. Check it out.
/ YM1401D 3-point lift problem #10
Ok I made it to my tractor today and took some pictures my 1510D has a positive detent in the lift up, neutral, and down positions. when the lift reaches the maximum it has an actuator that pushes the 3pt lever to the neutral position. The position of the controls for the actuator are adjustable. The first picture is with the lift arms down and the second with the arms up.
Mike in Warsaw (Poland)
PS. I was wrong in my earlier post in that the forward actuator actually controls the down position and the rear actuator controls the up position. The double nuts and spring are the position actuator for the up position and move the lever to neutral, when the max up is reached. Mine are almost at the end of the threaded portion as you can see.
I'm thinking it's something other than the adjustment linkage. Even when I completely disconnect the linkage it still works the same. With the engine off the lever feels normal, with the raise, lower and neutral positions. With the engine running, it lifts an inch or two, and the lever pushes itself toward neutral. Again, this is regardless of the stop linkage adjustment and even occurs with the linkage totally disconnected. Looks like it's coming apart again. :( Maybe a piece of dirt or something inside the valve? Thanks everyone for the help.
/ YM1401D 3-point lift problem #12
Is it possible that you got something out of place when putting everything back together ? Mabe go back & re -check everything.
Problem Solved!
The problem turned out to operator/assembler error. There is a pushrod that raises the 3 point arms that fits into the dished top of the lift cylinder piston. When I installed the lift cylinder assembly into the housing, somehow that pushrod slipped down so that it hung loose instead of fitting into the piston like it should. The lift arms would lift slightly because the piston would push on the piece that the pushrod was connected to as the piston reached the end of it's stroke. Hopefully someone will learn from my error. Thanks to all who replied.
/ YM1401D 3-point lift problem #14
Well done. It always gives me a great feeling of satisfaction when I figure out a puzzle like this, even if it was my own **** fault! :D
/ YM1401D 3-point lift problem #15
Problem Solved!
Good job! That's the reason that I asked you if you were sure that you didn't get something out of place durning assy. It happened to me (about a week ago )on my ATV winch . I took it apart to grease the internal gears ( as I ride in mud alot ) & when I put all back together it wouldn't wind the cable in . Took it apart 3 x:eek: b-4 I got it right ! Things happen that way sometimes:D
2022 DODGE RAM 2500 (A65643)
2022 DODGE RAM...
New/Unused Wolverine 78in Quick Attach Rock Bucket (A65583)
New/Unused...
2014 Kobelco SK210LC Hydraulic Excavator (A64553)
2014 Kobelco...
2011 Ford F150 (A66408)
2011 Ford F150...
Wolverine Quick Attach Hydro Slide Pallet Forks (A66408)
Wolverine Quick...
Cat GC25 Forklift (A65579)
Cat GC25 Forklift...
