ym 2210
   / ym 2210 #1
YanmarEd
Its on CL cheap says it ran out of fuel what kind of problems can that cause other than having to reprime fuel systym
   / ym 2210 #2
I would be suspect... why did the seller not reprime the tractor? I would take the time to inspect and reprime the engine before purchasing. If he baulks at the idea then more might be wrong. I have had good luck with CL but I am careful. Good luck!!
   / ym 2210 #3
what kind of problems can that cause other than having to reprime fuel system
None. Maybe a dead battery from cranking it, worst case.
Reprime: Open/bleed/close each bleeder screw in sequence: 1) fuel filter inlet, 2) outlet, 3) then the one down on the injector pump inlet. No need to bleed beyond the injector pump.
Like Mully said if the seller won't cooperate - run away. It's not tractor, its a lawn ornament.
TEST YOUR BID BUTTON! (A51248)
TEST YOUR BID...
2012 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2019 FREIGHTLINER...
2021 KOMATSU D39PX-24 CRAWLER DOZER (A51246)
2021 KOMATSU...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A51248)
UNUSED RAYTREE...
