ym 2200
/ ym 2200 #1
turkeyhunter
Ok guys I'm a new yanmar owner to. Can you guys tell me the ups and downs of the ym 2200 ? I hope that they are a few ups to. /forums/images/graemlins/grin.gif The only things I have seen so fare are that the tach and temp gauges dont work any replacements that I can buy say from tractor supply that will work ? All I have done so fare is bush hog for about an hour. But down at the shifter for the trans it seemed to be a little fluid coming out right at the rubber boot at the shifter. Is this some kind of problem ? What is the closest manuals I can get ? Thanks for the help.
/ ym 2200 #2
Post your questions over in the Yanmar forum, you'll get better response.
The tach probably needs a new cable, they don't get lubed very often, if at all. A temp gauge from the auto parts house will work, you might need metric adapters though. Fluid came out of my shifter boot too, I never replaced it, just used a zip tie to tighten it up. Or they probably have new ones from a Yanmar parts dealer.
Quite a few dealers here that can supply a close manual. Try Wayne at Little Miami
/ ym 2200
Very sorry 507 I thought I was there. Again sorry. But thanks for your help.
2008 THE MACHINE CO. THAWZALL H250 HEATER  (INOPERABLE) (A68842)
2008 THE MACHINE...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2016 Nissan Sentra Sedan. (A66738)
2016 Nissan Sentra...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2017 Ford F-150...
2012 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2012 FORD F150...
