YM 2000 - Roll Over
/ YM 2000 - Roll Over #51
Howdy y'all, newbie to the board here with a question. Exactly how do you put water in the tires? /forums/images/graemlins/confused.gif
/ YM 2000 - Roll Over #52
1)remove the tire/wheel. 2)Remove the valve core. 3)Submerge in large tank or pond until bubbles stop rising. 4)replace valve core and fill to required air pressure. 5)Reinstall on tractor. JUST KIDDING. you could pump it in with a bilge pump or something similar.
/ YM 2000 - Roll Over #53
Howdy jimbo welcome to TBM, look at the post from the first page, LMTC has three links that will show you how, I didn't know how they did it, but I guess the pond idea will work also LOL...Robert
/ YM 2000 - Roll Over #54
Darn it all, and I was just about to order that Water Compressor option from Harbor Freight for $17.95 /forums/images/graemlins/grin.gif
/ YM 2000 - Roll Over #55
If it is a tubeless tire, you can take the wheel off, lay it down , break the bead in a small area and fill with jugs.
Eugene
/ YM 2000 - Roll Over #56
almost any auto parts store will have a garden hose adapter.
move tractor until the valve stem is at the hight you want the water level to be. remove the valve stem. attach garden hose and turn on the water. when tire is inflated turn off water and press the relief valve and the tire will flatten. turn on water again. repeat until tire is filled to the level you want. I loaded some anti freaxe by cutting a short piece of old garden hose . attach the adapter to the valve and insert the hose into a gallon of antifreeze then jack up the tractor as the tire is lifted it will draw antifreeze into the tire. now add the water.
Dodge Charger (A56859)
2016 Volkswagen Tiguan SUV (A59231)
2016 Volkswagen...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
2005 Mitsubishi Fuso FE84D Auto Crane 3203 PRX 1.5 Ton Crane Utility Truck (A59230)
2005 Mitsubishi...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A59228)
2025 Kivel 48in...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
