YM-1700 Starting hints
/ YM-1700 Starting hints #1
Dingbat
Cedar Island NC (Outer Banks)
YM 1700
The fellow I'm buying the YM1700 from doesn't know much about Yanmars and doesn't have the book. He replaced the starter but is still having truble getting it started. He said it doesn't use glo plugs so is wondering if there is some trick? He say's there is a small container about 2x2" with a tube running out of it that appears to having something to do with priming it. Any counsel? Hoping to take delivery tomorrow. I'm clueless on this. Thanks, Steve
/ YM-1700 Starting hints #2
Fill the little bottle with diesel fuel. Get on tractor. You will have a key switch that has a position counterclockwise to the OFF position that is Thermostart. Turn the key to there and the fuel will drip in to the intake manifold and will be ignited by a small coil that will in turn warm the air in the intake manifold which aids in starting a cold engine much like glow plugs. On some Yanmars I have seen a chrome looking button on the dash that you push while the key switch is in the ON position. Of course for either of these to work the coil and associated wiring, etc has to be working.
Good luck with it. Unless where you are is really really cold, the Yanmars are usually easy starting tractors and rarely here in North Alabama have I ever used it. The only time I had to use it was on a big YM2620D Yanmar. The temp was in the low teens.
/ YM-1700 Starting hints #3
<font color="green">"I'm clueless on this." </font>
That's not how you got your handle, is it? /forums/images/graemlins/grin.gif
Nah...from listening to so much Darrel Lawson, Ricky Skaggs, Bill Monroe, Blurgrass Cardinals, Seldom Scene etc etc! Love it!
Dingbat is what they call folks who come to Cedar Island NC from elsewhere (even if it were only 20 miles away!) Its down with good nature. Steve
PROBLEM SOLVED! Thanks Brent! The fellow said he did what you said and she fired right up! Many thanks...ain't the WWW and this forum great? Steve
/ YM-1700 Starting hints #6
Ah... good ol' Bluegrass!!!!!
"ain't the WWW and this forum great? "
Yep, TBN is the best.
May I interest you in a TBN t-shirt? /forums/images/graemlins/wink.gif
/ YM-1700 Starting hints #7
Another way to help start is to use the compression release lever. Ther eis a little lever on the lower left side, with linkage running to the valve train. You can pull this and the engine will spin over faster due to no compression. This helps build some oil pressure faster, under no load. Then you release the lever, and usually fire right up. This in connection with the thermostart should get you in business.
Soundguy
/ YM-1700 Starting hints #10
I'll try, but I don't know how to attach another thread!
TBN T-Shirts - Pick Colors
#358334 - 01/05/04 06:14 PM Edit Reply Quote
Ok guys, this has been a long time coming... by popular demand, we're kicking off 2004 with TBN t-shirts.
Our plan is to go with the standard TractorByNet.com logo in the center, about 12-13" wide, as shown below.
The t-shirt itself will likely be a Hanes "Beefy T" in sizes M-5X. The colors we're considering are...
This is a photo rendering, so the real shirts will look better.
The TBN T-Shirt Color I Want is...
White
Orange
Washed Green
Royal Blue
Black
View the results for this poll
The results of this poll will determine which shirts will be made, and hopefully next week some time we'll take pre-orders as we did with the hats.
If everything goes smoothly you guys should be wearing your TBN shirts by the end of the month.
Muhammad
2013 Chevrolet  Express 2500 (A62613)
2013 Chevrolet...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
2022 Chevrolet Tahoe SUV (A61574)
2022 Chevrolet...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
HYD GRAVITY FED CAR LIFT (A64281)
HYD GRAVITY FED...
UNUSED AGT MX-MRW14 STAND-ON SKID STEER (A64280)
UNUSED AGT...
