YM 1700 head gasket
   / YM 1700 head gasket #1
puresol
Lavonia, GA
Yanmar 1700
I pulled the head off of my tractor this weekend, suspected blown head gasket. There was no gasket dressing, or so it appeared, put on the gasket. I know it specifically calls for it in the shop manual. Also there was a substantial amount of carbon build up on the block. Is everyone using gasket dressing of somme type? Is heavy carbon build up normal on the top of the block? Could I be so lucky for my problem to be an improperly installed head gasket? The head is in the shop currently being checked for cracks- keep your fingers crossed.
   / YM 1700 head gasket #2
Just read an old post from Aaron at Hoyes stating Yanmar head gaskets do not require sealant.
Thanks Winston1 I found it
   / YM 1700 head gasket #4
As a rule copperkote can be used on most all composition gaskets just fine except permatorque types (these are not them) to fill/seal small imperfections around water passages and its not a bad idea. I normally use copperkote on a head gasket of this type and did on mine when I had it down fwtw.
But the basic point/rule is gaskets are the seal all by themselves remember that. What most folks assume is because there are "sealers" that that means you must use them - not true and mostly not recommended by manufacturers either. hth
Is heavy carbon build up between the block and head "normal"?
I will use copperkote if for no other reason than my piece of mind.
   / YM 1700 head gasket #7
I'll agree with Aaron & Winston there's no need for it. The Only time I ever use a Sealent is when there is or possible problems with the Head or Block for that matter. Which in doing so is IMO. a typical Ghetto Rig. :D
   / YM 1700 head gasket #8
Can you post pics of the things you are asking about? btw I personally would like to see pics of the gasket on both sides. Yeah copperkote wont hurt a thing in this instance its optional though like I mentioned but peace of mind is a good thing.
Here they are if it worked-
Pallet Fees (A50775)
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
New Wolverine Skid Steer Root Rake Bucket Attachment 34'' (A53002)
New Wolverine Skid...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
