YM 1700 hard starting
/ YM 1700 hard starting
The that Hoye Tractors out Iowa Park Tx. has uses the clamps that hold the injectors in. I will use wood and solvent to polish the tips and toothpicks to clean the jet(YouTube). Hopefully the UPS guy gets here soon with the injector puller.
/ YM 1700 hard starting #85
Diesel Engine Compression Tester 2 Pc
Has anyone tried this, and/or know if any of these adapters will work on Yanmar?
I think you need a dummy Yanmar injector as an adapter between any gauge kit, and the head.
Hoye sells one that they had to have custom designed, so the adapters in common kits apparently aren't the right ones for our Yanmars.
Pulled the injectors. The Teflon washers under them are shot, had a heck of a time getting the back cylinder’s seat out so it could be cleaned. They are both clean and functioning well. Now to get the washers so a compression test can be done. I was able to rent the slide hammer from Hoye for $10 for ten days, had them both out in about ten minutes, that thing works like a champ.
/ YM 1700 hard starting #87
I may end up going to Iowa Park for work this year. If I do I hape to make a trip to Hoye and Meet Aaron @Hoye Tractor !!! Buy a few small things while I'm out there.
They have been great to work with. Shipping is a bit high, since I’m only 130 miles from them, but that’s the way it is anymore.
/ YM 1700 hard starting #89
I was working on a machine that I HAD TO get the tool/puller for..
I started out "renting" it for 10.00.. Then I looked at the invoice & shipping..
It was 25.00 to get it, it was gonna be 25.00 to ship it back + the 10.00 rental..
I called them up & told'm to mark that one "SOLD".. Lol
Its a BEEFY tool.. very well made.. even if u had the "plans"/specs, u probably couldn't get one made or that price.??
/ YM 1700 hard starting #90
THAT compression tester is for testing thru the "glow plug" hole..
THIS ONE is for testing thru the injector hole..
Diesel Compression Tester Set
I haven't tried it on a Yanmar tho..
One thing about getting the big kit is, u can always turn around & sell it after your done..
3PT 10' Rolling Cultivator (A60463)
3PT 10' Rolling...
2006 International 7400 SFA Terex Hi-Ranger 6TC-65 65ft. Insulated Bucket Truck (A60352)
2006 International...
(INOP) JOHN DEERE 450CE CRAWLER DOZER (A59823)
(INOP) JOHN DEERE...
2020 VOLVO VNL760 6X4 T/ A SLEEPER TRUCK TRACTOR (A59906)
2020 VOLVO VNL760...
John Deere 1025R (A53317)
John Deere 1025R...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
