YM 1700 hard starting
/ YM 1700 hard starting
Pulled the head again looked closer at the valves, they’re not seating completely(yep, shoulda done it earlier but been in a hurry) ain’t no big deal. I really appreciate all yall’s input, this is a great site.
/ YM 1700 hard starting #102
Hard to be for sure but that was my guess. Now Find out Why and hope it can be corrected easily and finish it up. Would I reuse the old H-Gasket? "NO". Maybe to get it running and then replace it with a new one and then you should be good to go :2cents:
/ YM 1700 hard starting #103
Glad you confirmed the valves weren't seating. At least now you have a new starting point. Hopefully it is an easy fix and nothing major. As Carey said, I would not use the old head gasket either, they are cheap, just get a new one that way if something isn't working properly you won't have to wonder if the head gasket is bad at that point.
Should’ve checked the first time off, just got in a hurry to get it running. Thx.
/ YM 1700 hard starting #105
I would not use the old gasket either...Unless I was in a hurry to use it. But I'd buy a new one expecting when slow to replace it or not be angry if it let go or whatever knowing it was used.
Worked the valves over, the head was a mess once I got them out. What is the spacing between the rocker arm and valve supposed to be? I know they need to be readjusted.
It runs, finally!
/ YM 1700 hard starting #108
:thumbsup:I could imagine that head was in bad shape. I was guessing it had ring problems. And the ether was my reasoning. Just keep I mind about the gasket and if it's worth replacing it. I would..
Never seen a head in this bad of shape, lots of corrosion on the back cylinder combustion chamber. Already have a new head gasket on the way. Thanks to all you guys on the forum.
/ YM 1700 hard starting #110
Could that be a cracked head with a water leak?
Didn’t see any, but probably would if I had it Magnafluxed. The original head gasket was badly broken.
/ YM 1700 hard starting #112
so, you are saying it runs ? Did you get the answer about the valve adjustment ?
I see where you asked and no one responded. I can look it up if you need it
/ YM 1700 hard starting #113
YM195 (YM1700) Operation Manual: Valve clearance 0.006", both intake and exhaust.
Same clearance for YM240 (YM2000).
Yes Ken, it runs. Got the specs online, thanks Cal. Thanks everyone for the ideas, introspection and head scratching.
/ YM 1700 hard starting #115
it just puzzles me as to why you couldn't see all of this when you had the head off the first time :confused3:
They looked alright till I got a spring compressor, then down hill from there.
/ YM 1700 hard starting #117
Glad you got it running! Those things can be a pain to figure out
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
UNUSED ATS PA400 ELECTRIC HOIST (A62131)
UNUSED ATS PA400...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
