Yikes! Well pump replaced.
   / Yikes! Well pump replaced. #1
Alan L.
Elite Member
Grayson County, TX
Kubota B2710
2005 was $2500.
2014 $5,672.34.
500 foot well, 5HP 20gpm pump, motor, and control box replaced. After the job was done I asked what if I put a 10 gpm pump, maybe a 2HP? Would have saved $2,000. Not sure I could tell any difference.
   / Yikes! Well pump replaced. #2
That is one heck of a well set up. Will it actually flow 20 gpm 27/7?
   / Yikes! Well pump replaced. #3
That is an expensive pump if it's just servicing a dwelling
Ag use might need it, but a house? Never!
   / Yikes! Well pump replaced. #4
Holy heck, you had me at 500 ft.
   / Yikes! Well pump replaced. #5
Thats a huge pump for a house a 2hp 10gpm would be plenty. ( depending on your static water level, flow rate etc..) But saying that the price isnt too bad if thats including installation. Just to pull a pump that deep runs $600. To $800.
   / Yikes! Well pump replaced. #6
2005 was $2500.
2014 $5,672.34.
My neighbor just put in a new well last year, 5 inch pvc, 200 ft deep, it cost $4500. I think it is a 1 hp submersible pump.
   / Yikes! Well pump replaced. #8
I'm not sure, but 600' TDH might not even be possible with a 2 HP pump, so you'd likely end up with 0 GPM flow.
   / Yikes! Well pump replaced. #9
I hope they upgraded the electrical feeding it. 5 HP is a whack of power.
   / Yikes! Well pump replaced. #10
Depends on the level of the water in the well. the pump only works against the elevation between point of use and the _top_ of the water. Of course drawdown also comes into play.
Harry K
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
BUNDLE OF USED GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF USED...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
FORD TW-10 TRACTOR (A51243)
FORD TW-10 TRACTOR...
