Yesterday's work.
/ Yesterday's work. #1
prs
Platinum Member
Logan, WV
JD 650, Ventrac 4500Z AJ02248
I mowed my yard and a large field for about 8 or 9 acres total. About 7 gallons of gasoline through the Kubota "Z" engine. All with the 82" contour mower (my only implement for the VT so far). The large lawn is a piece of cake, especially with the ROPS down so as not to crash into limbs of fruit trees. The big mower that I feared would be clumsy, is very very maneuverable and nimble. I like it, I like it a lot.
The field mowing has some wide open rolling area and some very steep areas as well and an "V" shaped end that puts me on steep grade fore/aft as well as starboard/port. The slope meter exceeded 30 degrees a few times (mind you I have mowed this same area since 1968 with conventional tractors and only flipped once). Actually, I mowed the very same area that flipped me on the JD 650 and MMM with the VT and the VT showed no instability there at all!
BUT, the VT tends so slide to side when on a 30 slope that is purely side to side or up hill and side to side. Down hill and side to side it sticks like glue. When it slides to the side it really gouges-up the turf. Turning around in that restricted "V" area was not too bad, I just had to be very careful to feather the speed/direction lever to prevent tire spin and no problem as I turned around in several back-forth steps. I did bottom-out in one very steep area with a dip in it and hand to shut the PTO off, raise the mower to more heavily load the tires and then backed out of the spot. I will remember that spot! Pretty scary.
One nagging feature of running steep side slopes with down hill to the right is how the two hydraulic levers mash into my side as my weight pushed me into them regardless the seat belt and arm rests. A seat that counter tilts would be nice.
I have one area of a little over an acre that I can not yet mow, just too wet; some flowing water still and now we are supposed to bet 1 to 3 inches of ran next two days! I have to do the initial mowing with my JD 650 as it is getting really tall and very heavy orchard grass and fescue plus lots of crayfish mounds in the wet areas. Also a good bit of steep going.
prs
/ Yesterday's work. #2
How about posting several photos.
/ Yesterday's work.
I plan on it, Jack. I have a GO Pro, but don't know much about using it. My Samsung Galaxy 5 phone is also supposed to be a decent camera and movie taker, no clue. My daughter has posted some pics for me and showed me how she did it, Greek to me. I managed to post some pics of my own and an hour later the pics were replaced with notices that I had removed them. No, I did not remove them. I am a dinosaur.
prs
/ Yesterday's work. #4
Prs, I share your issue with the control lever on steep side hills, I'm a wide guy and it's very annoying, this is why I prefer my old Steiners for steep hills, the front mount controls are never hit by accident. In reading your post, it almost sounds like you don't have enough weight transfer for steep side hills...if your running 30 degrees plus on side hills, I found that the slower I go the better. .i don't have that heavy 84 inch deck, just a 72 which I'm sure is easier to hold on a side hill..i second what Jack said..I want pictures!
/ Yesterday's work. #5
Videos are not necessary. Just plain static photos will do.
/ Yesterday's work.
Raw Dodge, I had the weight transfer maxed-out and was going very slow and you are right, very slow is the way to go in such situation. I was looking at that more difficult "V" area this morning as I drove down the driveway to work and was please to see hardly any ground disturbance and a nice mowing job.
I still have a good bit of string trim to do with the RedMax and Stihl. I try to limit that to three times a year on the larger portion of the cut bank at the bottom of that field. It would nice to put a BushHog PT-5 boom arm sickle bar on the rear this VenTrac, if ground clearance so allows and if BushHog ever resumes production of that expensive implement.
prs
/ Yesterday's work.
Harrrrrrrrrrrrrrrrr. Ya gotta watch how emotions are not shown on the web. One way of reading that reminded me of my Mom way back when I had creamed spinach or over cooked broccoli on my lunch plate; "You get what you get and you will be happy with it." But I get it. I will make an effort to get pics if it ever stops raining! Raining again this AM and supposed to tonight and and and.......... That is what I get for living in the middle of a deciduous rain forest.
prs
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2012 Ram 1500 Crew Cab Pickup Truck (A61573)
2012 Ram 1500 Crew...
Cat CB24B (A60462)
Cat CB24B (A60462)
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
2016 International DuraStar 4300 S/A Dump Truck (A61573)
2016 International...
2015 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2015 INTERNATIONAL...
