Yellow Jackets not being friendly
/ Yellow Jackets not being friendly #41
I have an in ground nest I need to exterminate... problem is it's in very close proximity to a stream feeding a pond with fish in it. Really reluctant to dump gas in the hole.
I have a powder I ordered online called Mother Earth D, that is completely harmless to the environment. I am not 100% if it would work for the bees, but it's process works by dehydrating any insect that touches the powder, so I would assume it would work. Here is where i bought mine from. I just bough the small bottles.
/ Yellow Jackets not being friendly #42
I had a nest under an air conditioner that needed to be taken out. Paper type nest about the size of a small beach ball. I did have an old fire extiguisher from a closed civil defense building. I shot it and froze the suckers to death. Worls great but I was too cheap to refill the extiguisher. So, Yes that does work but not cost effective.
/ Yellow Jackets not being friendly #43
I've not had a nest quite that big but when I have a nest that's of decent size I arm myself with two cans of spray foam, one in each hand and blast away. They never know what even hit them. I do worry about the ones that were out on a hunt coming back, seeing me and retaliating after what I did to their family. :shocked:
/ Yellow Jackets not being friendly #44
The good guys painting my house last summer reported a very active nest with a 2" opening next to the stump of a large ash tree at the end of an old stone wall 15 feet from the corner of the house. Many yellow jackets moving in and out all day.
I reacted big time to a single sting years ago and was tested and found to be allergic to them , but not any other "bees". Went through a series of desensitization shots which probably worked, but each one still looks like a little bullet to me.
So I waited til dark, covered up, dumped a quart of gasoline down there, set a board across the hole and skedaddled back inside. Didn't work. Called the exterminator. I didn't see him at his work, but there was a decent spread of powder around there for my hundred dollar bill. Worked.
/ Yellow Jackets not being friendly #45
When it comes to yellow jackets, I do nothing in moderation. I pour five gallons of diesel in the entrance hole and then go back the second day and dig it up. Then, I burn the dirt with more diesel. Then spread the dirt back and spread grass seed and straw. I was hit this summer while bush hogging a vacant lot. There were three different nests in the ground. It cost me a bunch in fuel, but I passed on the bill to the home owners. I actually saved them money as the exterminators would charge about $150 per nest.
/ Yellow Jackets not being friendly #46
When you discover a tree nest about head high or so, find yourself a simpleton you really don't like, give him a stick, blindfold him and tell him it's a pinata!:p
/ Yellow Jackets not being friendly #47
COLD !
E/S
/ Yellow Jackets not being friendly #48
I found another nest in my siding last night. Yellow jackets again. I put some of the Mother Earth D powder around the opening and was watching them fly through it to go in and out. I will let you know if they start dying.
/ Yellow Jackets not being friendly #49
I had an infestation of large brown wasps under the roof of my shed. I think there was 4 on one side and 2 on the other. The only thing I had available was diesel. I put about a gallon in my pump up garden sprayer and hit them with that. It wasnt an instant kill like gasoline, but also not as flammable. It did the trick. What I didnt realize is that someone had knocked down a nest which landed right by my front tractor tire which was flat with thorn puncture and needed to be fixed. I started loosing the lug bolts and had them all loose, then decided that I needed to use the FEL to raise the tire up off the ground. When is stepped across the nest to get on the tractor, nothing happened. When I jumped off the tractor, I stepped right on a portion of the next and they came for me. I got away from all but one. It wasnt a big next, maybe 50 wasp. I gave them a moment to settle back on the nest, then found a lid from my trash can. Got back over there, tossed the lid over the nest and did a Mexican hat dance on it. There must have been a bunch of wasp off hunting because for the next week, everyday, I had to crank up my diesel sprayer and spray spots on the ceiling where a dozen or so would congregate. They especially liked my outdoor spotlight. I never saw so many of those wasps. HUGE SOB at least 2" long and they just kept coming. I hope I got most of them since I had to leave home and come back to work and leave THEM to their work
/ Yellow Jackets not being friendly #50
You can try Volk Oil. I spray it on the lilies in my ornamental pond to kill aphids.
It does not hurt the fish. For the nest, use a heavy mixture in water with some dish soap for a surfactant. Just pour it down the hole.
I also use Ciper WD powder, mixed with water. Also Delta dust or Pyganic Dust is usually what the exterminators use.
I have not had good luck with the retail spray cans lately. I got a 3pack of Spectracide wasp spray at Home Depot and sprayed all three cans on this big hornet nest on our barn. No luck. It did a lot of damage but the hive is alive and well. I will have to mix up one of the above nasties and find a pump sprayer that will get up high enough to nab them.
Case IH True-Tandem 335VT (A60462)
Case IH...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 John Deere TX (A53317)
2018 John Deere TX...
JOHN DEERE 4450 TRACTOR (A59823)
JOHN DEERE 4450...
