Yellow Jackets not being friendly
/ Yellow Jackets not being friendly #21
No pollination abilities as far as I know, but they do eat a ton of mosquitoes and other assorted biting flies and spiders. I don't have issues with ground nests in my area, but have tons of smaller elevated nests. They are usually 3-8 inches across with 25-75 wasps per nest. They don't cause me much problem until they build close to a door or in my carport. When they do pick a high traffic area I knock them down with a wasp spray and remove the nest to prevent return of survivors. They ususally look for a safer location right away.
I grew up around Ft. Worth and I don't think the things you and I call "yellow jackets" are what the OP is talking about. Looked around on the web and decided they are a species of paper wasp like the red wasp. Mean little critters when you disturb them though.
/ Yellow Jackets not being friendly #22
I have heard that what you need is a hungry skunk. Apparently a little whiff of meat applied to a ground nest will bring Pepe around at dark and he will set in to digging and eating like my dad at an all you can eat buffett.
-jim
/ Yellow Jackets not being friendly #23
Well, they could be a paper wasp, but likely are yellow jackets. I removed a football sized nest from under my front porch about a month and a half ago after getting stung while minding my own business sitting on my porch..that was a fun trip to the urgent care(im allergic to pretty much anything that causes a histamine releasing reaction-poison ivy, bug bites, etc).
Anyway, I killed the one that stung me, smacked it before it left my calf. I googled many different descriptions and determined it was indeed a yellow jacket. They are primarily know for ground nests, but will also build paper nests in areas of hard soil. My entire property is clay, so that explains it. I just waited until it was raining outside(this means the bees would be in the nest)and crawled under the porch with two cans of bee spray and nailed the mouth of the nest. They all died and I immediately removed the remains from the joist with a stick. They haven't come back yet...
On a side note, the best/safest way to preserve the nest is to simply wait until the first good freeze. This will kill whatever is in the nest. You can then snip off the branch and display it as you see fit. Some people lacquer them, but it can be tricky and the paper can dissolve easily. My dad has one from last year he saved-no lacquer-just hanging in the garage.
/ Yellow Jackets not being friendly #24
I just killed 2 large wasp nests on my shed shere I store my tractor. The foam spray is by far the most effective. The were paper wasps with a white ring on thier tails, mean bastards. Works like a charm. I like the gas idea for inground nests. I will keep it in mind.
/ Yellow Jackets not being friendly #25
Insects don't breathe. They absorb oxygen through their "skin" and die near instantly from raw gasoline vapors. Gasoline vapors are heavier than air and if not burned will permeate down through the entire nest.
This may be the reason that, while I get swarmed with mosquitos here near sundown, as soon as I crank up my chainsaw they taper off a lot, almost completey. Maybe they don't appreciate the chainsaw's fumes?
/ Yellow Jackets not being friendly #26
I 2nd the foam shot spray can. Blasts the nest from like 15 feet. Covers it so thoroughly so fast they have a hard time even moving around, just like a big splat of sticky poisonous foam. They start falling to the ground within seconds. I had hornets; Not a one even flew off.
If you're still worried ... as I was before I ever used this stuff ... If you can drive your car/ truck over to within 15 feet of the nest, you can crack your window, spray 'em with a blast, & then put your window back up real quick.
I discovered, though, that the foam works so good & fast, I didn't really need to be in my truck.
/ Yellow Jackets not being friendly #28
I have run over the ground nests several times while mowing the pasture in the past 20 years or so and they always attack the black fel. bucket as I always leave it on for that very purpose. I don't know if they are color blind or not but hundreds of them just attack that black bucket. It gives me enough time to shut off the tractor and get away untill they are gone, usually less than a half hour. I have never been stung this way of doing it. I use the gasoline method after dark also if the nest is under ground and close to the house. I have used the spray can on a pole also if the nest is above ground and on or near the house.We have black bear in my area and they will attack the nests so if they can tell black maybe that's why they attack the black bucket if not it might be do the heat of the bucket, I don't know it just works for me while mowing.
/ Yellow Jackets not being friendly #30
I have an in ground nest I need to exterminate... problem is it's in very close proximity to a stream feeding a pond with fish in it. Really reluctant to dump gas in the hole.
/ Yellow Jackets not being friendly #31
In MN. We have Bald Faced Hornets that make the Big Paper Hot Air Ballon shaped nests with the entry hole in the bottom. They are more Black and White striped and fairly aggressive. The little ones that build nests in the ground around here are Hornets and they are the meanest little S.O.B's around. Bumble Bees and Wasps look mean but are fairly tollerant. I like the bees but not the Wasps, Hornets, Etc.:mad::mad:
/ Yellow Jackets not being friendly #32
techwrtr2, I believe that all you need to do is place and open container of gas in close proximity to the opening and the vapors will do the rest. That is what I got from Bxpanded's post. Maybe he can clarify it for you.
/ Yellow Jackets not being friendly #33
Hmmm..., having to quote myself to clear up a mistake. I meant to say what most people call yellow jackets where I'm from are NOT what the OP was talking about. Sorry about the confusion.
We have these yellow paper wasps everywhere (under the eves on the house and such), but the nests are usually pretty small. Generally not enough of them in a nest to kill anybody (unless you are allergic to them), but the stings will make you swell up pretty good -- especially if it gets you in the face.
/ Yellow Jackets not being friendly #35
Somewhere on this board, last year maybe, someone said to put a clear bowl over the entrance. They won't be able to get out, won't dig another entrance bec the bowl is clear, and will die.
Haven't tried it myself though.
/ Yellow Jackets not being friendly #36
If you want to keep the nest couldn't you get a fire extinguisher, go out at night, hose it down and bring it home.
I didn't say it would be cheap.
Wedge
/ Yellow Jackets not being friendly #37
You do need to pour some in the hole but just a very small amount as RaT has said. A few spoonfulls will likely do the trick. It will evaporate before it makes it to the creek. Don't burn it.
/ Yellow Jackets not being friendly #38
Wedge
that could be fun
/ Yellow Jackets not being friendly #39
I hate them. I was mowing on my ztr the other day at my moms house and ran over the top of there entrance and didn't know it. I felt something tapping my head and reached up and swatted it and got stung on the head. well I crushed him. I didn't know at the time when you crush one it emits a phermone or something that attracts the rest of his brothers to defend the little s---. so I got stung about 12 times and left my mower sitting in my mother's yard for about 8 hours before I could go restart it safely. I BURNT THE GAS JUST FOR THE SATISFACTION OF IT. I knew I didn't have to light it, I just wanted to at that point.
/ Yellow Jackets not being friendly #40
Actually they do not emit a pheromone, they just hollar to their buddies. It goes something like this; Larry, Carl, Clem, go git the others and tell um its the guy on the "your color" tractor. Git him good, he just ran over the hole to our home and he needs a good lesson. Bite him and sting him with the rocking motion I showed you where you alternate doing bite/sting/bite. This guys gotta go!
2022 EZ-GO ELITE...
2011 FORD F-150 (A65643)
2011 FORD F-150...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
Packer 750 Horizontal Grinder (A65579)
Packer 750...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
(1) 20 Yard Roll Off Dumpster and (1) 40 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
