Yanmar YM2002D
/ Yanmar YM2002D #1
whistlepunk
YANMAR YM2002D
Looking for a good 3T80U-NA good engine block. any avenues in trying to locate a good one would be much appreciated.
Thanks in advance.
/ Yanmar YM2002D #2
Just curious about what is wrong with your block? I owned a 2002D for several years.
/ Yanmar YM2002D
The number one cylinder has a vertical crack. I am in the process of rebuilding this tractor that my son has just purchased.
/ Yanmar YM2002D
Thanks, I will give these a shout out.
/ Yanmar YM2002D
Within the Yanmar YM model series, a YM2002 and the YMG2000 are they or would they be a perfect swap from a JD850 or the other way?
/ Yanmar YM2002D #7
I cannot give you a definite answer on that. I suspect they would but do not no for sure. I would feel confident the 2002 anad ymg2000 would interchange.
/ Yanmar YM2002D #8
I also owned a YM2002 at one time. I think the JD750 would be a closer match not the JD850. I own 3 JD850's and they are different.
/ Yanmar YM2002D #9
Woops, I wasn't paying attention, yes, 750, not 850.
/ Yanmar YM2002D #10
850 was told to use when the YM2500 Fredricks supplied was purchased. PTO was big time Crazy! I forget how many 2 shift levers either 4 or 5 gears 🥴
/ Yanmar YM2002D #11
This can be done with certain YM models. You would have to investigate between models thru their parts catalog manuals.
/ Yanmar YM2002D #12
I recall that Thread very well. Local.
2000 Ford Windstar Van (A61574)
2000 Ford Windstar...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
PALLET OF FLANGE CUT-OFF VALVES (A68842)
PALLET OF FLANGE...
ALLMAND MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
2018 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A66736)
2018 Chevrolet...
2018 WILDCAT (A67714)
