Yanmar YM2002D
/ Yanmar YM2002D #1
whistlepunk
YANMAR YM2002D
Looking for a good 3T80U-NA good engine block. any avenues in trying to locate a good one would be much appreciated.
Thanks in advance.
/ Yanmar YM2002D #2
Just curious about what is wrong with your block? I owned a 2002D for several years.
/ Yanmar YM2002D
The number one cylinder has a vertical crack. I am in the process of rebuilding this tractor that my son has just purchased.
/ Yanmar YM2002D
Thanks, I will give these a shout out.
/ Yanmar YM2002D
Within the Yanmar YM model series, a YM2002 and the YMG2000 are they or would they be a perfect swap from a JD850 or the other way?
/ Yanmar YM2002D #7
I cannot give you a definite answer on that. I suspect they would but do not no for sure. I would feel confident the 2002 anad ymg2000 would interchange.
/ Yanmar YM2002D #8
I also owned a YM2002 at one time. I think the JD750 would be a closer match not the JD850. I own 3 JD850's and they are different.
/ Yanmar YM2002D #9
Woops, I wasn't paying attention, yes, 750, not 850.
/ Yanmar YM2002D #10
850 was told to use when the YM2500 Fredricks supplied was purchased. PTO was big time Crazy! I forget how many 2 shift levers either 4 or 5 gears 🥴
/ Yanmar YM2002D #11
This can be done with certain YM models. You would have to investigate between models thru their parts catalog manuals.
/ Yanmar YM2002D #12
I recall that Thread very well. Local.
1963 Ford Falcon (A62613)
1963 Ford Falcon...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
2014 Caterpillar 420F (A64126)
2014 Caterpillar...
14in Digging Tooth Bucket Excavator Attachment (A64194)
14in Digging Tooth...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2018 Kenworth T680 (A64127)
2018 Kenworth T680...
