Yanmar tillers, 2
/ Yanmar tillers, 2 #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
How hard would it be to hook up a yanmar tiller to a non yanmar tractor? I want to get a tiller that I can use on either the ym1700 or my NH 1920 ( 33 HP ).
Is it better to just get a standard 3pt tiller?
Chris / soundguy
/ Yanmar tillers, 2 #2
Chris,
Yanmar tillers are 3PH just like any other, except for the pins spacing. Just move the arms in closer on the NH.
/ Yanmar tillers, 2 #3
It isn't as simple as just moving the arms in. The hitch pins on the tiller are set back further on the tiller. Many times when you hook an American brand tractor to a grey market tiller the tires will rub the front of the tiller body. I usually remove the lift pins, install 6 inch extensions, and then replace the pins. See my attached picture.
/ Yanmar tillers, 2 #4
Here is another picture.
/ Yanmar tillers, 2
Nice pics, and setups...
I Like thos big mf tractors... they were mf right?
Chris
/ Yanmar tillers, 2 #6
Brent,
Hadn't thought of the pins being too far back. I see what you're talking about.
/ Yanmar tillers, 2 #7
I can attest to that problem. My yanmar is down for a head gasket and my neighbor tried to help me till my garden. He has a Ford 801 and the rear tires rubbed the tiller when he tried to lift it, Bre3tt's solution would have worked.
/ Yanmar tillers, 2
What about longer lower lift arms. When i got my ym1700.. the lower lift arms on it were so short.. they were useless.. looked like tyranosaurus rex arms.. I replaced them with a set of lower lift arms found at tractor supply co... probably for like a ford 8n or something...
Chris
/ Yanmar tillers, 2 #9
I have a yanmar tiller that leaks oil - anyone taken one apart? Is it easy to replace the seal? I believe it's a RS1300.
thanks
/ Yanmar tillers, 2 #10
Yes that is a Massey. I think it was an MF150.
UNUSED WOLVERINE HYD TRENCHER (A64281)
UNUSED WOLVERINE...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
Kubota Diesel Engine - Pump Takeout (Skid Mounted) (A63689)
Kubota Diesel...
UNUSED ATSPOWER ATS-SP50 50 TON HYD SHOP PRESS (A64281)
UNUSED ATSPOWER...
2025 48in. Farm Jack (A61572)
2025 48in. Farm...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
