Yanmar FX42D
/ Yanmar FX42D #1
JFG
Hello all
I am looking for feedback on a Yanmar FX42D tractor for $8500 from Free-Tractor-Manuals.Com. Pictures look great. I will be adding a hoe and a FEL from the same source. I am wondering about parts availability and reliability? What is the best way is to judge tractor health during a test drive in a parking lot? They are offering a 90 day warranty. I am torn between something like a Kioti CK30HST with financing and warranty or Yanmar with more power and lower initial cost. I am wondering if it is likely the Yanmar’s cost of ownership is likely to equal the Kioti’s say 5 years down the road? Does anyone know if there is a JD model tractor that approximates this Yanmar?
Thank you
/ Yanmar FX42D #2
Since he is a broker who is the dealer that will service this tractor? The price is low for that size tractor that is why I ask.
What I look for on FX models (cant speak for FX42 in 7 years I have never seen one). Shuttle should shift strong with only minor hesitation. Grab the top of the front tires push pull from the side. Should not be sloppy, leaking doesn’t bother me but bad bearings do. No excessive pressure out of the crankcase breather. PTO should run smooth, no jerking in and out when engaged, no winning noises. I test all gear ranges focusing on the low gears since that is where most of the machine hours were used. 4wd engages and disengages and once engaged stays there. Run it at all RPM's. Three point raises and doesn’t drift.
That is a complicated tractor so they should sound like they know how to fix it and a shop to back it up. In your gut you will know in 2 min whether it is a good tractor. Ignore the paint and bodywork.
Buck
/ Yanmar FX42D #3
Ditto on everything Buck said. Also---even a YM3000 will eat a CK30 for lunch. The CK30 and a larger Yanmar is like apples and a whole orchard.
I don't know if we can get most parts for that unit. I have never seen one, and it always concerns me when a given model is in short supply. It doesn't mean anything inherently bad about the model, but the laws of supply and demand would indicate less parts availability for it. Make sure you know who is going to work on it...they all need work at some point.
/ Yanmar FX42D #4
It probably has a turbo and that should be checked. It is about $1200 for a new turbo for that model, which incidentally is available via John Deere. I think the 1050 or the 1070 used the same engine. Transmission hard parts, like shafts and gears are likely not available, so as Buck said, make sure everything is tight. With those disclaimers, I'll say the FX42D is quite a nice tractor. Do make sure that whomever you buy from has a shop, parts and a mechanic.
/ Yanmar FX42D
Thank you Dave Buck and LMTC
The potential lack of parts seals it for me. I was having trouble finding info on the FX42D and wondered if there was a parts supply out there. I appreciate the help. I guess it is back to looking.
Thanks Ron
/ Yanmar FX42D #6
Keep looking at Yanmar.
Bruce
/ Yanmar FX42D #7
We have had 2 FX42-Ds in the past, they are a nice powerful tractor full of bells & whistles The FX42 & FX32 are identical machines, only the 42 has a turbo as Dave stated earlier. And yes the turbo whistles.
We have an Fx42 on order, it will arrive here in March. It might be added to the collection if its a jewel. /forums/images/graemlins/smirk.gif
Ernies Imports
/ Yanmar FX42D #8
How many is that now Ernie?? You have to sell them every once in a while :)
Buck
/ Yanmar FX42D #9
Buck, I only own 3 machines at the moment, I ran out of room! Im down to 2 yanmar FX235-Ds and a hinomoto JF1. But im always on the lookout for a nice big machine to plow thru the woods with.
It just feels good to have the power when you need it I guess.
I just took on the Branson line, they have some real nice machines to offer. theres a 4210i sitting in the shop that I drool over everyday but its for sale too. /forums/images/graemlins/grin.gif
/ Yanmar FX42D #10
I have an AF33D with cab that you might just have to own :) Makes the FX series look like a wagon :)
For the first time ever I have more equipment than you. Yikes, I need to reevaluate for sure. Maybe counseling or something. There is probably a 12 step program, but hey nobody likes a quitter right.
Buck
/ Yanmar FX42D #11
Ernie, I don't see where anyone else has any FX235-D's. Does this mean you have the only ones brought into this country? Are they so good, you had to have them both? What is so great about them? In other words, if I would see one, should I make a point of buying it? If so for what reason? Thanks
/ Yanmar FX42D #12
The FX235 is a semi late model with a power shift, hyd tilt (ufo), and most of all quick turn, thats a lever that makes it front wheel drive only, and it will turn on a dime which is something I need between my rows of trees here.
we have an FX42 2= f215s 2= fx24s coming in a month or so
plus many others too.
Ernie /forums/images/graemlins/smile.gif
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
3147 (A63117)
3147 (A63117)
2005 LUFKIN 45'X102" FLATBED TRAILER (A67714)
2005 LUFKIN...
PORTA POTTY (A68842)
2024 CRUISER RV SHADOW CRUISER (A67714)
2024 CRUISER RV...
2018 CATERPILLAR D11T HIGH TRACK CRAWLER DOZER (A65056)
2018 CATERPILLAR...
