Yanmar FX335 Questions
/ Yanmar FX335 Questions #1
bockyEuclid
Rowlett, TX
Yanmar FX335
Please help me identify these parts.
A - Primary Fuel Filter?
B - Secondary Fuel Filter?
C -
D - priming pump or something?
E -
F - Oil Filter?
1 -
2 - low coolant?
3 - oil pressure?
4 -
X - hydraulic fluid reservoir? Is it supposed to be cloudy?
What are all the symbols next to fuel gauge, UFO, 1-5, and some misc japanese above UFO?
Also what is the button next to the light switch? On mine when I push it the low water level light comes on.
Pictures here:
Imgur: The most awesome images on the Internet
/ Yanmar FX335 Questions #2
A. Called a water separator, should have a screen in it.
B. fuel filter
D. Fuel pump
E. Called engine stop or "motor assy stop"
2. low coolant in overflow bottle
3. oil pressure
Don't know about 1 and 4. Just wondering if 4 could indicate pto engaged?
X. Power steering reservoir and should not be cloudy.
Don't know about the button you pushed but would think you have a horn button. Is it in another location? Can you find a horn on the tractor?
Thank you! I will go change the power steering fluid asap. What type of fluid should go in there? From what I have read some say ref ATF fluid, others say hydraulic fluid. Thoughts?
I am trying to do my research as fast as I can, but if someone can help save me some time, what type of fluid should I use for the whole tractor?
1. Engine oil type
2. Power steering fluid type
3. Hydraulic lift system (Is this the same fluid reservoir as the power steering shown in the picture marked X?) Or does the FEL and 3 point get their fluids from the transmission or even a 3rd place?
4. Transmission fluid type
5. What weight gear oil for the front differential?
6. Does the rear differential use its own separate oil or does it get fluid from the transmission?
So many questions!! But I will be na expert soon. I am about to take the 3 point lift off because the o-ring on the lift piston leaks so I have to replace that.
/ Yanmar FX335 Questions #4
I would just use the same transmission/hydraulic fluid in the the power steering. Just my opinion, doesn't make it correct.
Fluid & Oil Types
Transmission sump supply's all hydraulics except power steering. Same sump for rear differential.
Great that helps!
So I will get 15W40 Diesel oil. Shell Rotella is what I already use I'm my other cars so that is excellent.
I will use 90 weight oil for the front diff, and I will look for JD303 "Hydraulic/Transmission" oil from local tractor supply.
Thank you again!
There is a filter inside the water separator and a spring. However, the parts manual does not show there is supposed to be a filter in there. And the top of the housing is not flat, there is no where for the filter to seat to, so basically its just floating around in the fuel doing nothing. The manual does list a "float".
Should I remove the filter and just leave the cup empty? Or try to locate a filter of some sort?
/ Yanmar FX335 Questions #8
1 might be park brake (my YM14 has this and it flashes when on) and 4 looks turbo related, possibly max boost?
2015 Gravely ZT 42in. Zero Turn Commercial Mower (A64194)
2015 Gravely ZT...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
2020 CATERPILLAR 259D3 SKID STEER (A65053)
2020 CATERPILLAR...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
